Old 09-08-2015, 07:59 AM   #43
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
If you want the best small air compressor set up, then look no further than this one. It isn't cheap, but it will reach all 4 tires on my 31' Classic and is quite fast for such a small compressor.
Product : Extreme Outback
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 09-08-2015, 08:41 AM   #44
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Our 2014 Classic has a GVW of 10,000 pounds and when loaded for camping there are two tire at 2,050 pounds, one at 1,950 pounds and one at 2,150 pounds. These load weights exceed the derated capacity of 1,983 pounds for the 15" Michelins I used on the 25FB and are using on the 23D. Thus we are using the 16" Michelins at 75 psi and the TPMS says they are happiest at that pressure for our load.
Old 09-08-2015, 01:02 PM   #45
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by KYAirstream View Post
How much does your trailer weigh when loaded? From looking at 16 inch wheels, I've noticed that the most common load rating seems to be LRE. For my trailer with a loaded weight no more than 7500, I'm wondering if LRE is too much? What do people with lighter trailers do when upgrading to 16s?
The wheels have a load rating of 3,850 each.
My trailer weighs 8,800# ready to camp.
I know the wheels are overkill, but are necessary to mount a 16" LT load rage E tire.
If I ever have a flat, I can remove the flat tire and tow with 3 tires on the ground still safely supporting the weight.
I compare it to hi-fi sound equipment- headroom = margin of safety = peace of mind = pleasant, relaxing towing experience for the driver and his DW-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-08-2015, 01:12 PM   #46
Gainesville , Florida
Don't you have to figure tongue weight when checking loads? Are your tire weights with the trailer and WD hooked up? Tongue weight takes weight off the trailer tires, yet using WD adds some back on. Or am I confused, wouldn't be the first time. That's why the axles sometimes aren't rated as high as the gross weight, the tongue weight takes some away.
Old 09-08-2015, 07:26 PM   #47
KYAirstream's Avatar
Northeastern , Kentucky
I think most take their weights with WD applied so they know how the trailer is loaded when ready for travel.
The difference of the axle weights of only the TV and the axles weights of the TV with the trailer hitched without WD provides the tongue weight of the trailer.
KYAirstream is offline   Reply With Quote
Old 09-08-2015, 07:27 PM   #48
The wheels have a load rating of 3,850 each? That seems like a high load rating. What tires are you running?
Old 09-08-2015, 07:29 PM   #49
Also, what PSI are you running for your 8,800lb trailer?
Old 09-08-2015, 07:31 PM   #50
Nice setup! You are certainly right about the $$ though.
Old 09-08-2015, 10:45 PM   #51
switz's Avatar
2014 31' Classic
Images: 8
I had the Classic up on two sets of four individual wheel weights detached from the truck and with the ProPride attached to the trailer. These numbers are necessary as a baseline to determine what the WD system is actually doing. I know that when parked, where the loads are on my tires and wheels.
Remember GVW also applies when parked in terms of loading the trailer suspension. So if I were to have have six 350 pounders over as guests, I have grossly overloaded the trailer suspension and tires.
WD does not take weight off of the trailer tires. In a perfect world, the total tongue weight would be evenly dived three ways: trailer axles - truck rear axle - truck front axle. So when WD is energized, more weight is transferred back to the trailer axles, not removed.
That 3,850 pound number is the load rating of the SenDel T03-66655T wheel at 80 psi. The Michelin LT225/75R16/E LTX M/S2 tire is rated 2,680 pounds @ 80 psi.
Old 09-09-2015, 07:01 AM   #52
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
Besides load being over weight limit for a tire, or under inflated, or aged out, tread separation can be caused by poor support when leveling the AS. I used to be somewhat careless with the width of boards I put under my AS when leveling up in a campground, and sometimes only supported the middle half of the tread if I was short on good boards. After I had two tread separations not related to under inflation or over load, I discovered that when we run our tires up on boards or blocks the support needs to provide for equal support across the full width of the tire and be reasonably level as well. It makes me really appreciate level spots to camp.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 09-09-2015, 08:06 AM   #53
Cumming , Georgia
Hi KYAirstream,
Many members are running the TST TPMS, I would be happy to discuss the system with you. My name is Mike Benson with TST. If you would like to discuss it, you can reach me at 770-889-9102.
Mike Benson
TST
mbenson1234 is offline   Reply With Quote
Old 09-12-2015, 06:46 PM   #54
Ravenna , Ohio
I don't understand your math
8,800 /4 =2,200# each tire assuming the unlikely 50/50 axle to axle split plus the unlikely 50/50 side to side split. But even then that means one side i.e. one tire would be loaded to 4,400. What tire are you using with that capacity?
Tireman9 is offline   Reply With Quote
Old 09-12-2015, 06:51 PM   #55
Ravenna , Ohio
snip
snip
Sorry you don't really have to worry about GVWR when stationary.
The concern for GVWR is braking and GAWR for highway travel speed on tires. 0 mph tires can carry a lot.
Now maybe your frame may fold up due to your guests but you aren't overloading your tires at zero mph.
Old 09-12-2015, 07:05 PM   #56
m.hony's Avatar
2013 30' Classic
It has nothing to do with math or the weight of my trailer.
The wheels are rated to support 3,850 each.
2 of the wheels would be adequate to support a single axle trailer up to 7,700#.
4 of the wheels would support a tandem axle trailer of up 15,400#, or a 14,000# GVW trailer or one with (2) 7,000# axles.
The fact that in my particular scenario, a 10,000# GVW trailer with (2) 5,000# axles, the wheels are complete overkill and have more than enough "headroom"/margin of safety/carrying capacity.
The 3,850# weight carrying capacity per wheel is specified by the manufacturer.
The wheels will support 15,400#, but in my case they only support 8,800#, the weight of my trailer ready to go.
Nothing to do with math, and the wheels are beyond adequate.
The tires also have more weight carrying capacity than I need.
The weight might not be distributed precisely 50/50 front to rear or side to side, but it is fairly close by design of the trailer and weight distribution applied, especially when the rig rides close to dead level.
My rig appears to ride slightly nose down, so one would think there would be more weight/pressure on the front axle, but the worst tread separation was on the rear axle.
Even slightly nose down the weight distribution front to rear or side to side will not be far from equal across the 4 tires/wheels-
TAC #MS-10
Airforums #70955
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 07:34 PM
Tires may not be to blame for tire failure fordfarmer Axles 2 05-18-2015 09:47 PM
ST Tire Failure Beginner Tires 7 12-03-2006 06:14 PM
If you have a tire failure Beginner Tires 6 07-09-2006 08:14 PM
Six whole months Pahaska Our Community 3 12-02-2002 08:44 AM
