Old 08-27-2004, 07:08 PM   #1
Tire Curtain
There is a track of some sort located above my tires on my 1971 Overlander. It looks as if it held some sort of curtain to hide tohe tires. Did they come this way? Where might I get a curtain to fit this slot. It appears that you just thread something in through the side and pull until you get to the end.
happier is offline   Reply With Quote
Old 08-27-2004, 07:35 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I believe, ZipDee made both the tire covers & the snap-on window awnings you are looking for ~ if you contact them with your trailer year & model, they will probably be able to provide replacements for you.
Both were offered as upgrade options.
Shari
Old 08-27-2004, 07:59 PM   #3
RivetED's Avatar
North Central , USA
Yes, it is ZipDee, we have seen these accessories at the A/S store. The current ones (at the store) are only for the 34'ers.
RivetED is offline   Reply With Quote
Old 08-27-2004, 08:09 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i have a set of zip dee tire curtains for my excella, they attach with snaps.
quality units, have left them on the trailer all winter 4 times with no ill effects. they have brass grommets in the bottom corners that allow for a bungee cord to be attached behind the tire to keep them in place.
if they are dirty in the spring i just toss them in the kenmore when the better half isn't looking!
john
you call them ferrets, i call them weasels.
Old 08-27-2004, 08:59 PM   #5
Vintage RV
1959 24' Tradewind
Atascadero , California
Images: 14
Send a message via Yahoo to plowboy
My '59 Tradewind has tracks above the wheels also. I figured it was for tire covers, but didn't think covers were still available.
Paul
plowboy is offline   Reply With Quote
Old 06-02-2005, 01:46 AM   #6
1992 34' Limited
Falls Church , Virginia
Question to John HD
John -
Thanks for your previous help - all working swimmingly by the way. SilverToy sit happily in the driveway, sucking and the electric we give her. Fridge and Iinverter keeping here happy - so that I can go out and be happy in her when the house and kids get to be toooo much. Go out there and read some John Clancy and get my 'patriotism fix' and then back to the SOS.... Am I right?
Found an older thread where you mentioned getting the ZipDee awning for the Tire Curtain area. Firstly, cost - How much do I need to persuade my lovely bride to play along with this expense? secondly - do they match the rest of your Awning material alreadu on SilverToy? Lastly, any last thoughts or insights on the color scheme question that will doubless ask the dumdest bolthead in the crowd to try to identify the color combination. NO FEAR!
Maybe, rediculous ammounts of MGD will put all present, into an appreciable state of mind, to carry out this endeavor!!
Ciao for now!
Axel
SilverToy is offline   Reply With Quote
Old 06-02-2005, 07:46 AM   #7
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
here's a pic of my trailer, sporting these covers whilst parked in the PO's back yard. I was under the impression that they had these made up from an old awning...perhaps they were store-bought? same vinyl material that was used on the original rear-window awning, which is still in use. (not visible in the pic, though).
3 snaps attached to the skin, just above the wheel wells.
I haven't been using them. probably should be, although, I will say that I am parked in the shade most of the time. But I just "re-tired" (doh!) the PO's tires...9 years old, according to the DOT tag, and they looked brand-spankin' new. hated to do it, but the "replace by age, not wear" advice seems fairly universal. Anyway, perhaps the regular use of these covers explains why they looked so new, and lasted so long.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-02-2005, 06:19 PM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
axel
glad to hear things are going well!
can't say i remember exactly what the tire covers cost, too many millers perhaps. i think in the 150 range.
having them match the awning is a definate yes!
try calling up zip dee and see if they can help you, i have heard they sell factory direct and have excellent customer service.
here is a pic of mine...
john
Name:	tire skirt.jpg
Old 06-09-2005, 01:05 AM   #9
1992 34' Limited
Tire curtain sounds so....well, you know! Perfect!
John HD -
Getting ready to give ZipDee the order but am having to sit down fisrt as they want over $400 plus S/H and all that. WOW! Haven't gotten to the talk about the match with the rest of the awings - has that reds, brown and grey and white look. Actually looks quite good on the trailer but do they still produce it and/or have it in stock. Current issue.
Did 'covers' for my enclosed utility trailer, ( 7x14 ) with dual dexter axles, out of some OSB sheets that I picked up at the local recycle yard. They were just laying there and so I asked, "do you mind if I get these panels for myself (signs all over about "NO trashpickin allowed". They said, "hell yes help yourself! The more you take the less I gotta deal with".
Got 2 perfect 4x8 OSB sheets and 25 or so 2x4x12 (REALLY TOP MATERIAL!!!) that had been used as some sort of a box for artwork or something. Really well constucted. Figure I got $75 worth of material. Got it all home and cut the OSB to size for the fenders on the Utility trailer.
Anyway, the ZipDees are still on my wish/to do list. Will get a check off there SOON!
Axel
anyone: 10-ply "E" 7-15 Del-Net tire??? jmeredith Tires 13 07-09-2009 06:31 PM
Tire Cracks Action Tires 3 06-14-2004 01:09 PM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
Flat tire... Craig Tires 10 07-11-2003 12:49 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
