I purchased an Argosy 26, 1973; days before we went to our winter home. Now that we are back home I can start some of the needed repair work. I noticed the front tires only are badly cupped on the outside edge. The rears have age and wear but no cupping. Is this from the P O running very low tire pressure? Or some type of a tire/axle problem. Looking for ideas or things to check. RAY
Hi, and welcome to the forums.
If the cupping is random on the tire, both on the inside edge and outside edge, you have a balance problem, possibly added to by loose wheel bearings.
If the cupping is a series of diagonal flat spots radiating out from the center of the tire to the outside edge, you probably have at least one bad axle.
The cupping frequently comes from bad bearings or poorly adjusted which allows the wheel to wobble. There can also be an out of alignment problem which can cause the same thing at certain speeds. You need to repack the bearings anyway and check the brakes. Not too many places are around that can check alignment of trailer tires and axles.
front tire "cutting" is called "river wear". it's caused from travelling great lengths in a straight line...more or less....all over the road semis experience the same problems. this happened in my country coach..i had the balance/alignment checked and they told me this was what caused it...keep on driving, there's nothing you can do to stop it.
Tires are out of balance. Get them rebalanced and rotate them to the rear. If at all possible balance on the trailer. This will balance the entire rotating assy. (Tires, wheels, & drums)
Also if you have shocks, now might be the time to replace them. It will help you tire wear issue.
>>>>>>>>>>>>>>>>>>>>>>>Action
Off topic, but .....ANOTHER MEMBER FROM MARCO ISLAND!!!! Hi Van!
Give me a shout sometime since we're like 'neighbors'
Did I ever work on your CC?
lewster
