Old 03-31-2009, 02:43 PM   #1
1976 31' Sovereign
Rockford , Tennessee
Tire cupping
My 1976 31' International has a problem with the cupping of one of the tires. The right front tire begins to cup with only a few hundred miles on the tires. I have heard there is away to align the frame, but I can't find anyone that seems to know who does this knid of work. I only run biased tires. Track
track is offline   Reply With Quote
Old 03-31-2009, 03:59 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
First off are you sure that tire is balanced? If you are happy with the balance and think the axle is bent Gommers in Chambersburg Pa can align the axle. A test for alignment is to lay a straight edge aside the tires and check for a gap. I use an 8 ft florescent light bulb.
2004 Excursion 4x4
Old 03-31-2009, 04:32 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You are less than a 5 hour drive from the factory. Take it there. It may not be the axle. It could also be a bad bearing. They can test and fix whatever it is in less than a day and you can stay in your trailer overnight for free.
Old 03-31-2009, 05:25 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It could also be a problem with the axle, you didn't say how the tire was cupping, but when our Argosy needed an axle, one of the tires had cupped tread in a diagonal pattern from inside of tire toward the outer edge of the tire. The outer edge of the tire was worn worst.
Old 03-31-2009, 06:04 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Ditto on the pattern. Different patterns mean different things. Can you post a photo?
Tire Help Newlyweds Tires 7 07-02-2008 10:30 PM
Tire cupping or scalloping Ray H Tires 5 04-21-2007 07:21 PM
Cupping tire wear, Why? Ganglin Tires 2 02-05-2007 06:52 AM
Tire ? Stream 1529 Tires 8 08-04-2006 10:55 AM
What is behind my tire? jkenny Axles 6 01-21-2004 01:21 PM
