Old 06-14-2004, 12:36 PM   #1
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Tire Cracks
I have a Q about tire cracks and the locations .....
What causes a tire to crack in between the tread? In the side wall around the bead?
(Other than replacement after the event or covering the tires) What can be done to prevent tire cracks in the tread? Tire cracks by the rim around the bead?
Does tire protectant (sprays) help at all?
>>>>>>>>>>>>>>>>>Action
Old 06-14-2004, 12:43 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Drying out is the main issue, as the tires age they leach the chemicals that keep them pliant into the concrete or blacktop. The longer they sit the more they lose. Once cracking starts it can't be stopped. To prevent, some rest the tires on a board underneath.
Also you can use protectants that prevent the UV damage from the sun and that will help the other smaller cracks that develop. I have been trying the Turtle Wax brand tire wax with UV, it has seemed to help keep mine looking good for awhile with reapplication every few months.
I have also seen the tire "sun block" sold at Rv suppliers.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 06-14-2004, 12:55 PM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
what does the board do? are you saying that heat from pavement accelerates this process? so parking on turf or other bare ground would be preferrable? hmmm..
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-14-2004, 01:09 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Does the spray stop or slow the "drying" process?
My trailers are exposed to the Phoenix weather. Read that as lots of sun. I have recently purchased tire covers. (Although my boat trailer tires have always been covered with some old vinal material draped over the tires) The boat trailer is parked on 2"x4"x8" paver bricks and the Airstream is parked on gravel.
My boat tires cracked around the rim by the bead. My Airstream tires have cracked in between the tread. What is difference in usage for the two trailer that has caused cracks in different locations?
After I replace the tires what can I do differently?
>>>>>>>>>>>>>>>>>>Action
anyone: 10-ply "E" 7-15 Del-Net tire??? jmeredith Tires 13 07-09-2009 06:31 PM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
tire replacement? cracks daydreamer36535 Tires 4 08-17-2003 06:23 PM
Flat tire... Craig Tires 10 07-11-2003 12:49 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
