Old 05-26-2015, 06:36 PM   #1
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Tire Cover Idea
Given the relative low volume of threads on this topic (including one from 13 years ago that references a Zip Dee product for this purpose) I'm going to venture before asking there are hundreds of reasons not to do this.
But here goes.
I have 4 of those "Adco" tire covers. You know, tan like an SOB would want on its tires, weird fake pleather fabric with fuzzy polyester backing that wraps around your tire and a long Velcro strip you have to thread behind the tire to catch on the other side to keep it on during wind.
They work. And this is a first world problem for sure, but sheesh what a pain in the butt when you come back from a long trip and just want to unhitch and run.
I was thinking - it would be GREAT if I had a snap on "curtain" of sorts I could just unfurl and snap on in seconds - whether for long term parking or even when at a campsite (I never put the Adcos on while camping but the sun hits the tires while camping too &#128515.
I'm guessing no one has done this since I can't find it with Google and perhaps for good reason. But what do folks here think?
Old 05-26-2015, 07:08 PM   #2
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Old airstreams have easy snap on stripe covers, not sure how they work in wind. I only use my covers for the winter. We r always on the mover in the Summer
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 05-26-2015, 08:36 PM   #3
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I've seen pics of older, more permanently parked Airstreams with skirting, but I don't remember where. Here is a link to a person who had skirting installed an his Airstream. The pic shows the wheel well skirting that uses boat curtain fasteners around the wheel well. Is this kind of what you are thinking of?https://chinesebuffalo.files.wordpre.../dsc_00171.jpg
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 05-26-2015, 09:51 PM   #4
W , New England
Something like that, TinShack - yes, thanks. Only no skirting around the entire trailer, just at the wheel wells - and I wouldn't want to rivet the snaps into the shell itself but in to the wheel trim that frames the wheel well.
Old 05-26-2015, 10:17 PM   #5
TinShack's Avatar
2005 28' Safari S/O
You could make them long enough, or sew some tabs on them, so you can park the wheels on them, and then just fold them up to snap in place in the wheel wells. This would keep them from flapping in the wind.
Steve
Old 05-27-2015, 04:29 AM   #6
W , New England
Also a good idea, TinShack!
Old 05-27-2015, 05:10 AM   #7
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Or put some weight in the bottom of them.
I have those, too, but mine are white. I usually only use them when I know we're not going to be camping for a while, such as when I winterize - and even then I sometimes forget or never get around to installing them.
There's a third option: Spray on tire cleaners have UV blockers, too. Spray and done. You'll have to redo it every few weeks, but then if you're really worried about the sun on the tires while camping, they'll be protected already. And on the road.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 06-05-2015, 02:20 PM   #8
Ravenna , Ohio
My white covers drop over the tires and have a short piece on the inside that holds them on. look like this one.
No velcro or other strap needed.
I published test results showing the advantage of using tire covers vs no cover on my blog.
I have seen flat "screen" material used on some Class-A units. The open mesh lets cool air circulate to keep the temperature down.
People talk a lot about UV but high temperature can damage the tire structure while UV might only damage the outside tire surface.
Solid black covers are worse than no cover as they heat the tire and prevent cooling air from circulating
Retired tire engineer (40 years). Write a blog on RV tires.
Tireman9 is offline   Reply With Quote
Old 06-05-2015, 02:28 PM   #9
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Snap on tire covers are comon on white box trailers. At least down here in my neck of the woods. I use the double covers, easy on and off.
MICHAEL
Old 06-09-2015, 03:10 PM   #10
Ravenna , Ohio
Spray on "UV" protectant does nothing to prevent the tires from cooking in the sun.
This "backing" can contribute to tread separations.
Old 06-09-2015, 03:28 PM   #11
AWCHIEF's Avatar
Images: 33
I have TST tire sensors. The last few days I have been monitoring the air pressure and temp. The temp behind my covers on both sides has been averaging 12 degrees below ambient (in the low 90s during the day). Tells me that they are providing good over temp protection.
MICHAEL
Old 06-09-2015, 05:51 PM   #12
W , New England
AWCHIEF - what brand are yours? I've seen several - do yours have fabric that goes over the tops of the tires down behind them? I can see how the tandem cover would be less prone to wind problems. That could work - or that Rube Goldberg plan I'm cooking up might happen 😃
Old 06-09-2015, 06:25 PM   #13
ckottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We use the large cover that goes over the tandem wheels as well, giving good air flow between them. The wheels are spoke design to allow air flow through them. They are black, maybe grey is available next time, can't stand to look at white wheel covers on the Airstream.
So they don't blow off in the wind we run a bungee front to back in the furnished grommets.
cheryl
ckottum is offline   Reply With Quote
Old 06-09-2015, 06:50 PM   #14
AWCHIEF's Avatar
Images: 33
AWCHIEF - what brand are yours? I've seen several - do yours have fabric that goes over the tops of the tires down behind them? I can see how the tandem cover would be less prone to wind problems. That could work - or that Rube Goldberg plan I'm cooking up might happen ��
From Camping World, they go over the top of the tires and have grommets. They fit snug enough that I normally do not tie them down. If a storm or excessive high winds come along I have a couple of bungee cords to use. So far have not needed them.
Overdrive RV Dual Axle Tire Cover - Tire diameter 27-30", Grey - Classic Accessories 80-108-041001-00 - Tire Covers - Camping World
MICHAEL
Need a soft tire cover for front-mounted spare tire! Bessie1968 Tires 10 05-10-2013 10:05 PM
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 08:40 PM
Tire protection, tire cover and airconditioning leong1 Tires 0 06-22-2009 04:02 PM
to cover or not to cover tfetterer Winterizing, Storage, Carports & Covers 8 09-16-2008 12:14 PM
To cover or not to cover goldenlily Winterizing, Storage, Carports & Covers 1 10-03-2005 11:48 AM
