Old 06-16-2015, 07:37 AM   #21
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Here is a picture of a 1989 Avion that had the snap-on covers for the triple-axle 34VB. You could easily modify the design to have the snaps in the wheel well area rather than on the skin of the trailer. They could be weighted easily.
Our 1987 Avion 34W has evidence of prior wheel /tire skirts and an entire tropic room. I plan on getting some fabric, probably from Zip Dee, to make new wheel/tire covers. I also know of a local tent/awning business that would probably also be a good source.
On our silver trailers, the snaps are barely noticeable, at least mine are. They are installed along the rivet line above the wheel wells and blend in with the rivet line.
ID:	240772   Click image for larger version
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 06-16-2015, 08:00 AM   #22
Rich W's Avatar
I'm In , Kentucky
Originally Posted by AWCHIEF View Post
Snap on tire covers are comon on white box trailers. At least down here in my neck of the woods. I use the double covers, easy on and off.
Mike, where do you store yours? We have double on one side, singles on the other. They seem to collect spiders and other creatures. I used to put them in the SUV but now I fold the covers and put them in the propane cover box.
You probably have a pickup so maybe not an issue for you.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 06-16-2015, 08:31 AM   #23
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Parked in my front yard with one side on the drive way. So far no issues with bugs. I keep the area around the trailer sprayed down with bug killer and cut short. I do have a neighbors cat that likes to snooze on top of the wheels. And nope I no longer have a pick up. Currently driving and towing with a 2011 Jeep Grand Cherokee Overland 4WD with 5.7 Hemi. After removing I always give the covers a good shake, roll up and usually tuck them down behind the seats in the Jeep.
MICHAEL
Old 06-16-2015, 11:02 AM   #24
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
My covers are not so clean as to tuck them anywhere but hosed off, brushed off, dried and stuffed in a bag for future use. Fortunately the AS is walking distance from my house but the parking is on a pavers track with grass edges, oh well. The things we have to put up with no rent, walking distance to the house and with water and electricity, WOW!
BTW, my tire covers come FREE with the SOB cover for our last RV.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 06-16-2015, 11:40 AM   #25
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I went with the patio screening that is used for window covers & such on RVs. It comes in 70% and 90% light transmission, I went with 90%. It snaps on my plastic fender skirts (EB only), comes with the fabric looped at the bottom edge so any kind of weight could be inserted. Looks a lot like the pix of the skirted classic posted early this thread.
"Chip Tank" is in Westwood Ca.
CDONA is offline   Reply With Quote
Old 06-16-2015, 01:43 PM   #26
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
My boat uses an aluminum track attached to the boat and welting stitched onto the canvas to hold up the canvas curtain for the cabin. The track is about 6' long and shaped to fit the cabin contour. The welting on the canvas is the same length. When I want to hang the canvas, I just slide the canvas welting into the track. It goes in very easily. A few snaps on each side keep it in place.
You can buy the track and welting online. Curtain, Canvas & Upholstery: 1 1 4 x 1 2 Canvas Upholstery Track Welting @ tacomarine.comI think you could attach the track to the wheel well trim using the existing screws that hold it in place, then, with the welting stitched onto some Sunbrella-type fabric cut and finished to fit, slide it into the track. A couple of snaps inside the wheel well would hold it in place. You could also stitch some lead weights into the bottom of the fabric to keep it from flapping in the wind.
This would save you from drilling any new holes with the exception of a couple inside the wheel well for the snaps.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 06-16-2015, 01:54 PM   #27
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Tireman...
Why do we use tire covers on our trailers and not on our cars?
John
John Audette
Air Cooled Porsche Specialist -
Two roads diverged in a wood, and I took the one less traveled. ~ Robert Frost
John&Vicki is offline   Reply With Quote
Old 06-16-2015, 04:51 PM   #28
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Dang, TinShack - that could work too! So many options! Thanks!
Old 06-16-2015, 05:18 PM   #29
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
What TinShack is describing sounds like rails that are on my '62 Tradewind. I think these rails are factory installed, and I've never been 100% sure what they were for. But tire covers are really the only thing that makes sense.
Name:	6-16-15 Download 001.JPG
Thalweg is offline   Reply With Quote
Old 06-16-2015, 05:46 PM   #30
TinShack's Avatar
2005 28' Safari S/O
Attachment 240834
Yes, that is like the track I'm referring to. The newer Airstreams have a trim piece that is screwed on inside the wheel well, so rather than rivet it to the side, I was thinking it may be better to utilize the screw holes that are already there. For you Thalweg, since you already have the track, making the covers with the welting would be all you need.
Steve
Old 06-17-2015, 08:22 AM   #31
Ravenna , Ohio
Originally Posted by John&Vicki View Post
Tireman...
John
Variety of reasons.
Most car tires get replaced at 4 to 5 years
Many cars spend a good portion of their lives in garage
Car tires have a 15% to 25% margin on load so they have less structural damage done when driving (remember over half of all RVs have one or more tire in an overload situation)
All cars since 2002 come with TPMS so the driver is alerted to a loss of air. I bet that fewer than 10% of RVs have TPMS
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
Tireman9 is offline   Reply With Quote
Old 06-20-2015, 05:48 PM   #32
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Tireman...
John
Car tires don't usually age out - usually you've put enough miles on them that they need to be replaced simply due to wear before they age out (5 or 6 years). But, people like me that have vehicles we don't drive as often do have to watch the tire age. I just replaced a set that were 7 or 8 years old on my car (I probably got away with fudging the date a bit because I keep it in a garage and use the car often enough to keep them from dry rotting - but, at least one of them was bad, giving me vibrations at highway speed, so it probably wasn't going to be long before I had a blowout or something).
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 07-04-2022, 04:01 PM   #33
DRJJL
1985 31' Sovereign
Poway , California
My 1985 AS Sovereign has a channel above the wheel well. I’m thinking there must have been sew-in plastic tabs to draw inside the channel. Does anyone know?
drjj
drjudy is offline   Reply With Quote
Old 07-04-2022, 04:21 PM   #34
DRJJL
1985 31' Sovereign
Poway , California
I found the item in 15’ lengths at SAILRITE.COM.
drjj
Old 07-04-2022, 04:22 PM   #35
DRJJL
1985 31' Sovereign
Poway , California
I found the vinyl welting in 15’ lengths (enough to cover both sides of dual axel) at SAIKRITE.COM. About $1 per ft in 2022.
drjj
Old 07-15-2022, 07:14 PM   #36
DRJJL
1985 31' Sovereign
Poway , California
My aluminum channel has ID of 5/16 (8.5 mm) and that’s the same OD as keder tape sold by sailrite and vts. So it won’t slide easily. I see keder has a website and sells all thicknesses. I found this two minutes after they closed so will call next week. Will probably go with 6mm.
drjj
Old 07-16-2022, 01:58 PM   #37
2022 27' Globetrotter
DALLAS , TX
I have TST tire sensors. The last few days I have been monitoring the air pressure and temp. The temp behind my covers on both sides has been averaging 12 degrees below ambient (in the low 90s during the day). Tells me that they are providing good over temp protection.
I thought TST sensors are not active unless they sense movement? From what I recall reading, the display will continue to show the most recent measurement that was recorded when the tires were in motion last, but it's not representing the current conditions when the vehicle is not moving.
They do this in order to save battery power.
I'll have to dig up my owners manual and see ...
foobar is offline   Reply With Quote
Old 07-16-2022, 04:34 PM   #38
CruizinDux's Avatar
Washington , Missouri
Originally Posted by SteveSueMac View Post
Thanks.
So I'll try to describe the Rube plan. I gave up on the snaps idea - just hate the idea of drilling holes in the Tin Goat.
So - I'm imagining a rectangular vinyl fabric with a weighted pole on top that would be draped over the top of the tires and drop down to the axles while the rest of the fabric comes back over the tops of the tires and hangs down to the ground.
To keep them attached and not bothered by wind, I'm thinking one of the following:
A) make them long enough so you drive over the vinyl bottom part then roll up the vinyl from the bottom to the top and place the weighted rod over the tops of the tires, or,
B) have a bungee attached to each end of the pole that attaches to a grommet on the sides of the vinyl covering the tires, or
C) another weighted pole sewn across the bottom part of the vinyl cover.
Of course - the tandem you shared in the link seems pretty darn simple 😃
Steve, this us my rube solution since in a prior life managed housing rehab.
I asked a roofing contractor client for a couple of section of TPO roofing. i forget the mil thickness but it was often spec for commercial roofing and had life expectancy 50 + years. generally white on the weather side , i told him what i was thinking ( X x X") so he hammered in a couple of brass eyelets in the top corners. i hook a bungee to the top corners and lift it over the tire, than fold the side excess around the tire. done!
i'll look for a pic
btw saw that a BH punched the big ticket at Westminster and thought if you and the boys! congrats!
WashMoBob
CruizinDux is offline   Reply With Quote
Old 07-16-2022, 08:18 PM   #39
CruizinDux's Avatar
Steve, here ya go. Nothing fancy but works. About as Rube as it gets.
I don't travel with them, so I just roll them up and leave them in my storage space and on occasion bring them home to hose them off.
WashMoBob
Need a soft tire cover for front-mounted spare tire! Bessie1968 Tires 10 05-10-2013 10:05 PM
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 08:40 PM
Tire protection, tire cover and airconditioning leong1 Tires 0 06-22-2009 04:02 PM
to cover or not to cover tfetterer Winterizing, Storage, Carports & Covers 8 09-16-2008 12:14 PM
To cover or not to cover goldenlily Winterizing, Storage, Carports & Covers 1 10-03-2005 11:48 AM
