Old 06-14-2011, 10:50 PM   #1
1973 25' Tradewind
1964 19' Globetrotter
Centerville , Utah
Tire clearance inside wall?
Purchase 4 new Greenball Towmasters for my '73 Tradewind. Now there's less than an inch clearance between the inside side wall and the wheel well. I'm not too concerned about the wheel well itself, but there's a piece of aluminum along the bottom of the wheel well that would quickly turn into a disaster if the wheel ever caught the edge. Did I make a mistake on getting the bigger tire, 10 ply vs 6 ply?
tclay
Stormy Weather is offline   Reply With Quote
Old 06-15-2011, 12:33 AM   #2
1985 31' Excella
Fresno , Texas
If you have a blowout it probably won't make a lot of difference that trim will probably get some damage. I had a tire that even damaged the wrap behind that trim. The important thing is to always maintain tire pressure and check the tire temperature when traveling, especially on hot summer roads. It is also good to keep them out of the sun when in storage and remove as much load from them and the axles as possible.
There are several on here that have gone from 15" to 16" wheels and tires and have a close clearance.
Wsmith is offline   Reply With Quote
Old 06-25-2011, 10:24 PM   #3
calivw78's Avatar
1969 31' Sovereign
Larkspur , Colorado
Checking tire pressure is something I've always done, but not tire temperature. Are you using an infrared temperature monitor, and what temp is too high?
1969 Sovereign Restoration Project
http://airstream.calivw78.com
calivw78 is offline   Reply With Quote
Old 06-26-2011, 12:18 AM   #4
OO , OO
Send a message via Skype™ to cruiser54
I install "TireMoni" - system and everything is under control! Does not cost a lot, temperature and tyre pressure registers on the monitor, constantly!
Werner
cruiser54 is offline   Reply With Quote
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 08:34 PM
Wall Covering Pictures Roadrunner Upholstery, Blinds, Walls & Interior Finishes 7 05-19-2011 11:50 AM
Interior Wall Structure Strip chowman2011 General Interior Topics 3 05-17-2011 09:09 AM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 11:10 PM
Had the honor to step inside a 1962 Bambi this weekend and fell in LOVE with the heat J5MM LP Gas, Piping, Tanks & Regulators 9 03-14-2011 03:52 PM
