Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 05-04-2005, 09:21 PM   #1
Profile:
Tire blowout damage
Just bought a 99 Safari, 23'.. in Tuscon Arizona.. returning home to Wyoming, Blowout on left rear tire.. on Interstate..tire lost cap after beating the tar out of the grey and black water holding tank outlets.. broke T handle and valve from both tanks.. (guy behind me was useing his windshield wipers..) Insureance Adjuster isn't here yet.. some damage to rocker panel behind rear tire, w/courtesy lite and switch, also moulding around tire well.. question is, if holding tanks themselves are okay, could I do the repairs? (Trim carpenter for 35 years..) your thoughts? thanks Les
Les Staley is offline   Reply With Quote
Old 05-04-2005, 09:27 PM   #2
'97 Excella 25
Bob Thompson's Avatar
Profile:  Corpus Christi , Texas
Images: 60
Most of the work around the holding tanks isn't high tech, just nuts and bolts kind of stuff. Rebuilding or replacing valves isn't very difficult. Once you get started, you'll quickly be at ease with it.
Just curious, was the tire that blew out a Goodyear Marathon?
2002 Toyota Tundra
Not that Bob Thompson, the other Bob Thompson!
Bob Thompson is offline   Reply With Quote
Old 05-04-2005, 10:53 PM   #3
7751
Torii's Avatar
Profile:  1975 25' Tradewind
Huntington Beach , California
Sorry to hear your tale. Hopefully it can all be repaired. How old was that tire? Was it original equipment?
If you look around in these forums you will find lots of info on tires. The Goodyear Marathons have a bad reputation for blowing out. When I had mine installed a few weeks ago I asked the installer about it and he told me that they did have a bad mold for awhile but it had been fixed... (pointed out a "s" marking on the sidewall that indicated the new version. Take it with a grain of salt... )
In my humble opinion 5-6 years is a long time on a trailer for a tire. (any brand) Mine were about 7 years old and had allot of hatching and the beginnings of tread seperation. They also had plenty of tread left and looked to be in great condition at first glance.
Torii is offline   Reply With Quote
Old 05-05-2005, 07:22 PM   #4
Profile:
Blowout
Bob Thompson, and T man: yes the tires are Goodyear Marathons.. I'll be changeing them before I roll out again.. What type of tire do I look for? they say "trailer" on the sidewall. Thanks for your replies.. Les
Old 05-05-2005, 07:26 PM   #5
Profile:
Original Equiptment
I bought this trailer from the dealer in Tuscon.. he said he had sold it as a new unit, and stored it for the first owner.. I'm the second (actualy, my signifigant other is the second, I just pull it for her).. (and I guess, fix it)... the tires are original, so six years old.. time for a change. Les
Old 05-05-2005, 08:18 PM   #6
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Airstream Registry
Yes it was time to change those tires. Personally I believe the dealer shouldn't have left you off the lot without advising you that they needed replacement. I won't leave a tire on any trailer once it hits year 5, no matter what the brand. I've never had a tire failure in 25 years of towing. My last 3 trailers have had Marathons with no failure ever occuring. I don't think I would be wrong in stating the major causes of trailer tire failure are either underinflation, or keeping a tire on past its useful service life.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
Old 05-06-2005, 11:29 PM   #7
Tinsel Loaf's Avatar
Profile:
Good, well maintained tires, brakes, axels and hitch are money in the bank.
Tinsel Loaf is offline   Reply With Quote
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
Tire opinion Dbraw Tires 12 11-25-2002 07:39 AM
Blowout John Brimer Airstream Motorhome Forums 3 08-27-2002 05:15 PM
Flat tire detector Pahaska Tires 6 08-08-2002 06:38 PM
Tire code info FrankR Tires 1 05-20-2002 09:18 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
