Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 09-10-2004, 01:01 PM   #1
Profile:  Corona , California
Tire balancing?????
A way to fine tune a tire balance???
NOT!!!
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-10-2004, 02:53 PM   #2
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
hey andy,
have you ever noticed how tandem axle trailers always seem to get objects stuck in the rear tire and seldom in the front?
my prior set of marathons picked nails up in the rears only, and most of our trailer tire problems at the power company seem to be mostly with the rears also.
i was told by my goodyear dealer this happens because the lead tire "stands" the object up and the rear tire gets punctured by it.
waddaya think?
john
you call them ferrets, i call them weasels.
Old 09-10-2004, 03:00 PM   #3
john hd
Historically, rear tires on a tandem seem to get the nails and bolts etc.
This particular tire was on the rear.
I would agree with your observation as it seems to happen far more than not.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-10-2004, 03:23 PM   #4
Profile:  , Minnesota
Images: 59
Airstream Registry
The only 'proper' way to fine balance a tire is with 1 5/8" deck screws. Nails are a definite no-no. Use plenty of Vulkem when inserting the screws. Heads should be counter-sunk about 1/8".
Old 09-10-2004, 04:07 PM   #5
markdoane.
I'm sure you meant to say "plated" deck screws............
But in my photo, it's a 1/4 inch "plated" hex head bolt, fine threads, of course.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-10-2004, 04:27 PM   #6
Images: 59
Airstream Registry
Yes, my mistake. Always use zinc plated screws. Cadmium plated screws will do in a pinch, but zinc is more anodic and provides better galvanic protection.
Of course if you have a later model airstream with 5052 aluminum, then zinc is required, because cadmium is cathodic to the 5000 series.
Old 09-10-2004, 10:56 PM   #7
JohnG's Avatar
Profile:
Gee Andy,
I like those nifty balance weights that you just insert in the tire. What part number is that again?
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 09-10-2004, 11:02 PM   #8
Creampuff
Creampuff's Avatar
Profile:  1957 22' Flying Cloud
Malibu Lake , California
Images: 60
O.K.- So which one do I use for 2024????
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 09-11-2004, 06:38 AM   #9
Images: 59
Airstream Registry
Here's a partial galvanic series. Generally the higher items on the list will corrode in contact with items lower on the list:
MAGNESIUM ALLOYS
ZINC
ALUMINUM 5052, 3004, 3003, 1100, 6053
CADMIUM
ALUMINUM 2117, 2017, 2024
MILD STEEL (1018), WROUGHT IRON
CAST IRON, LOW ALLOY HIGH STRENGTH STEEL
CHROME IRON (ACTIVE)
STAINLESS STEEL, 430 SERIES (ACTIVE)
302, 303, 321, 347, 410,416, STAINLESS STEEL (ACTIVE)
Of course any metal imbedded in a rubber tire will not cause galvanic corrosion.
Old 09-11-2004, 06:52 AM   #10
Profile:
Don, as you say, "any metal imbedded in a rubber tire will not cause galvanic corrosion"; ASSUMING there is only one foreign object stuck in the tire!
Rick
Rick Alston is offline   Reply With Quote
Old 09-11-2004, 07:25 AM   #11
Images: 59
Airstream Registry
Rick
Whoa! That one slipped right by me. Right you are!
Old 09-11-2004, 07:50 AM   #12
Ken J's Avatar
Profile:  1958 26' Overlander
Tijeras , New Mexico
Hmmm, I've got a front tire on the trailer that has a nail in just like that, Andy - reminds me to get it fixed because I'm using the trailer next weekend - not bad because I only loose about 5 lbs of pressure a month.
Ken
1958 Overlander
Ken J is offline   Reply With Quote
Old 09-11-2004, 10:04 AM   #13
Ken J.
What a way to lose trailer weight!!!
If you have a tandem axle Airstream, 29 to 31 feet, reduce the tire pressure from 60 PSI to 10 PSI.
That saves 50 pounds of weight per tire, or 200 pounds total.
Now, if we replace the air in the tires with Helium....................fill an internal bag with Helium, we might be able to reduce the trailer weight thats on the ground to maybe 1000 pounds total.
Benefits??? Saves wear and tear on the tires, AND, reduces the load on the axle rubber rods, increases the 90 day or 500,000 mile (which ever comes first), to 200 years or 50,000,000 miles, which ever comes first.
Of course, as always, the warranty is good to the original owner, only.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-11-2004, 11:15 AM   #14
Images: 59
Airstream Registry
And if you put in an adjustable water pressure regulator, you can reduce the water pressure from 45 PSI to 5 PSI, and save another 40 pounds. Also, let the air out of your spare tire to save another 60 pounds.
And loosen your lug nuts. All those ft-lbs really add up.
If you drain all the magic smoke out of the battery you can save a few more pounds. I don't recall how much an amp-hr weights, but I'm sure someone has the conversion factor. I think it's about 2.5 lbs per amp-hr.
Wheel balancing beads nickcrowhurst Tires 19 05-17-2005 11:53 PM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels 3 09-06-2003 02:25 PM
Flat tire... Craig Tires 10 07-11-2003 12:49 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Tire balancing - one more time !!! femuse Tires 25 02-26-2003 06:04 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
