Old 09-11-2004, 11:37 AM   #15
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Wow you guys are way smart - never thought of such a practical way to reduce trailer weight. Hmmmm maybe I can trade my Avalanche for an old VW microbus (still need wheel base) - could even take the air out of the tow vehicle tires.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 09-11-2004, 02:01 PM   #16
WayWard Wind's Avatar
2004 25' Safari
I'm not a "learned" person, but all this air you're leaving out of the tires, wouldn't the weight you leave out depend if it's "hot or cold air" ? Also when the air is "heavy" doesn't it always seem to settle lower ? If that's the case then one would want to leave the heavy air out of the bottom of the tire. Right ? Please correct if I'm wrong, because like the small amount of $$$ I have left after buying an A/S, I prefer to have a low inflation rate.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 09-11-2004, 02:31 PM   #17
A. E. Milliman
We have submitted your technical questions to Corky for his perusal.
He has duly advised us that he has taken your submitted technical questions under submission, but will not render his decision, until the supply of his favorite biscuits has been sufficiently replenished.
Ah yes, it is a "dogs" world.
Old 09-11-2004, 03:43 PM   #18
Images: 59
Andy,
I thot Corky only worked on Wednesday mornings? Does he get overtime, or will we need to wait until Wednesday for an answer?
Old 09-11-2004, 04:51 PM   #19
Ken J's Avatar
Durango , Colorado
Images: 14
Andy - I think we need some more engineering data on this
I thought it was a simple matter of reducing the number of pounds in the tire and water system, now we seem to have a lot of hot air to consider
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 09-11-2004, 05:46 PM   #20
Creampuff
Creampuff's Avatar
1957 22' Flying Cloud
1971 31' Sovereign
1976 29' Ambassador
Malibu , California
Images: 60
Further reduction deduction
I was thinkin' that maybe if I change-out my lead tire weights for magnesium ones, I could save a few pounds!! Then again why not just get rid of them and be done with it!
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 09-12-2004, 04:35 AM   #21
Creampuff
Your idea sounds similar to Fox News; "Air and balanced reporting".
Rick
Rick Alston is offline   Reply With Quote
Old 09-12-2004, 05:26 AM   #22
Some years ago , a J.B. Hunt driver, did let air out of his tractor trailer tires so he could get across the scales. . Not talking bad about truck drivers mind you. Toby
Toby is offline   Reply With Quote
Old 09-12-2004, 07:00 AM   #23
till's Avatar
Lisle , Illinois
Images: 108
OK, we have removed thus far....
Pounds of air
Pounds of water
Pounds of electricity
Pounds-feet of lug nut tourqu (sp?)
and installed Helium
in the tires
in an envelope in the cabin or by sealing the cabin all together....
But we still have to worry about galvanic corrosion.......
But what about a magnesium frame??
Also, what does a BTU weigh?? I have always heard Air Conditioning measured in tons. Man think of the weight savings by getting rid of that monster weight sitting up there!!!!
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 09-12-2004, 08:59 AM   #24
Images: 59
A Btu weighs 2.666 ounces.
Old 09-12-2004, 11:42 AM   #25
Ken J's Avatar
Durango , Colorado
Images: 14
See I balance my tires that way too
Works great!
Name:	Nail in tire.JPG
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 09-12-2004, 11:46 AM   #26
Unfortunately, every so often we have to learn to tolerate "hot air."
At the present time, two varieties of hot air, "surround us."
One is the Heinz variety and the other is the Texas variety.
The problem is not so much with the Texas variety, since it's only one or two.
The real problem is with the Heinz variety, since they claim 57 of them, "in writing no less."
Ah..........election years, what would we do without them?
Old 09-12-2004, 09:48 PM   #27
Creampuff
Creampuff's Avatar
1971 31' Sovereign
1976 29' Ambassador
Malibu , California
Images: 60
Originally Posted by Ken J
Works great!
No Ken, your method is different- you are using "attached thumbnails'- those are lighter!! Are they galvanic too??
Murray
AIR #189
Old 09-13-2004, 10:14 AM   #28
Ken J's Avatar
Durango , Colorado
Images: 14
What I find works best is galvenized roofing nails - less likely to rust - I would think the rust combined with hot air would add too much weight - there for throwing off my original intention of fine tuning the balance.
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Wheel balancing beads nickcrowhurst Tires 27 06-07-2010 07:24 AM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
Flat tire... Craig Tires 10 07-11-2003 12:49 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Tire balancing - one more time !!! femuse Tires 25 02-26-2003 06:04 PM
