Old 11-02-2010, 01:47 PM   #29
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I have had a Doran 360 unit for about 2 1/2 years. I first bought a Pressure Pro, but couldn't find a place to mount the monitor. My dashboard doesn't like suction cups and Velcro doesn't stick to it well enough to keep the monitor steady. There's no effective place in the dashboard either. So I returned it to Doran and exchanged for their model which at the time had better mounting options.
I used the 3 suction cups on the windshield. They are bulletproof—it has never budged. It's kind of a stretch to reach it while driving.
I think they now claim the batteries in the sensors last 8 years. I remove them after a trip thinking the sensor is no longer sending a signal and therefore the batteries will last longer.
The locking part is the same as described in a previous post. The allen screws are tricky to get locked on and not jammed in so far they won't come out. The end of the allen wrench is very small and can round enough to not be able to take the screw out, but you do get a couple with the unit. Usually you can just screw the whole lock off with the sensor anyway without loosening the screws. This past summer the inside of the locking screws got filled with road tar and I couldn't get the stuff dissolved, so had to get new locks.
Last week, one sensor started acting crazy, seemingly not sending a signal all the time. Then the monitor started giving crazy readings. I will reprogram it ands hope it works next year.
When I had Marathons, I had to keep adding air every few days, so removing the locks and sensors was a pain. With better tires, they don't lose air.
I am very glad we got the TPMS as it probably prevents damage to the trailer if a tire blows. Maybe better tires are also a solution to that. It also allows me to check tire pressure every morning and during the day without going around to each tire with a gauge—easier and quicker. The TPMS reads 3 lbs. differently from a hand tire gauge, and I tend to believe the tire gauge more, so I just take that into account.
I am hoping I just have to reprogram it since software sometimes acts up after a while, and all will be well.
Gene
Old 11-02-2010, 03:10 PM   #30
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
I have not had any tire balance issues with the Pressure Pros on the metal valve stems and I move them from the trailer and TV (we have 8) to the motor-home as needed.
-Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 11-02-2010, 03:42 PM   #31
dznf0g's Avatar
Oswego , Illinois
I have the Doran. I didn't rebalance when I installed ONLY because I am due for new tires soon. I do run Centramatics though. I will have new tires/wheels balanced with TPMS sensors installed.
Old 11-02-2010, 03:49 PM   #32
Master of Universe
Gene's Avatar
dzn', have you had any of the problems I have had with the Doran? How long have you had it? Now that I recall, 2 different sensors have acted up at different times.
Also, I have Centramatics and believe they compensate for the weight of the sensors.
Gene
Old 11-02-2010, 04:14 PM   #33
dznf0g's Avatar
Oswego , Illinois
Gene,
No problems, but I've only had them about 2 months and maybe 1000 miles. I do remove them when not rolling for a few days. I believe they turn on only when pressurized. Save batteries?
Has there been others reporting problems? Have you called Doran? Keep us posted.
Old 11-02-2010, 04:20 PM   #34
Master of Universe
Gene's Avatar
Don't know. Haven't called. I'll see what happens when I use it next spring.
Gene
TPMS - Dill internal mount system wingfoot321 Tires 10 04-19-2016 08:39 AM
Valve stems and TPMS cosmotini Wheels, Hubs & Bearings 8 08-06-2013 07:28 PM
Another TPMS... reday Tires 3 07-05-2009 04:53 PM
Second thoughts mgann Member Introductions 1 03-26-2007 10:24 AM
Your Thoughts Please... tin can luv Our Community 11 08-24-2004 12:04 AM
