Old 12-27-2006, 07:32 PM   #15
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
michelle
just make sure you retorque those lug nuts after 100 miles!
john
you call them ferrets, i call them weasels.
Old 12-27-2006, 07:46 PM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Okay.
Originally Posted by thecatsandi
Ok you show me yours and I'll show you mine.
Here's mine. I got an error message: File too large. Had to chop the far end off it...
Old 12-27-2006, 07:52 PM   #17
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Well they are probably coming back off in about 100 miles. The dealer will remove them to check the brakes. When I get to the can opener I will have tocheck them again. I checked them when I got the trailer and on lug nut on each wheel was loose.
Michelle TAC MT-0
Sarah, Snowball
Old 12-27-2006, 08:00 PM   #18
Keymar , Maryland
Ok here is mine!
Michelle TAC MT-0
Sarah, Snowball
Old 12-27-2006, 08:05 PM   #19
2007 25' Safari FB SE
Suburbia , Sunny So Cal
I am getting toolbox envy. It only takes two strong men to lift mine. Yours need a forklift.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 12-27-2006, 08:10 PM   #20
Well Preserved
1993 21' Sovereign
Michelle's and mine both roll pretty easily. When I have to move mine, I call a flatbed towtruck. Can you say "hernia"?
Old 12-27-2006, 09:00 PM   #21
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Ok here is mine!
Hi, is that your new, three bladed, tow vehicle? That doesn't look like a Diesel to me.
Old 12-28-2006, 05:54 AM   #22
Keymar , Maryland
Bigger and Bigger
I had a low trailer with a ramp I could roll it into. I sold it when I moved. The moving company was the last ones to touch it. the out the low trailer it does require a fork lift to move the thing
Michelle TAC MT-0
Sarah, Snowball
Old 12-28-2006, 05:55 AM   #23
Keymar , Maryland
Yeah! its turbo charged and fast!
Michelle TAC MT-0
Sarah, Snowball
Old 12-28-2006, 06:28 AM   #24
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
May be exessive, but I bring a torque wrench with me and check the torque before moving down the highway....also check tire pressure too.
Old 12-28-2006, 05:10 PM   #25
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
I carry three things. Two 6,000 lb capacity plastic ramps in case I need to lift an axle, a torque wrench, and one of those big lug nut tire doohickies.
I highly impressed some young people in Mt. Vernon, GA a couple of months ago. I came limping into town in slow motion with a shredded tire thumping, thumping. I pulled into a closed gas station, grabbed my ramp and the doohickie, placed the ramp, aimed the driver's mirror at the tire, backed the trailer up onto it, and removed the tire.
Then I got the spare out, found out it had 35 psi in it (note to self - stick back up there with valve pointing downward!), and spent the next 35 minutes with my little 12 VDC air compressor running to get it up to 65 pounds.
Then I put the spare on, pulled it off the ramp, tossed the ramp in the back, and I was on my way. I was also PARANOID about my other tires, of course, by then. It was the second tire failure of the trip.
If the spare had been full of air, I would have been Mr. Cool.
That tire is leaning against my garage now, and it still has 65 psi in it.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 12-29-2006, 06:12 AM   #26
Keymar , Maryland
I am still working on what I need for the road. I do have roadside assistance but it may not be available everywhere I go. The Cell phone does not always have a signal. I am goign to do a little shopping today.
Michelle TAC MT-0
Sarah, Snowball
Old 12-29-2006, 08:52 AM   #27
Well Preserved
1993 21' Sovereign
Michelle, you really only need two things:
1- Every tool you own.
2- Credit card to purchase the one tool you don't own, but need to perform the repair.
Old 12-29-2006, 09:29 AM   #28
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Michelle, You are such a trooper! You are so good at turning a problem into a learning experience. Hats off to you!
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
