Old 03-19-2016, 02:04 PM   #43
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I went with 5 Michelin 15" 235/75x15 when I purchased my preowned Airstream 2008 Classic 25fb in April 2013. They look a little squished but when I check the pressure they are right on 50lbs. I use a TireTraker TPMS system on the trailer tires. The sensors screw onto the valve stems. They monitor the pressure and temperatures. The new wider spare fits in the cradle on the A frame just barely.
When its time to replace these tires I'll probably switch to the 16" rims and Michelins. I may forego the spare since I doubt it would fit into the cradle under the A frame but I'm not 100% sure.
Kelvin
Old 03-19-2016, 02:36 PM   #44
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
The choice you've made is a good one.
I've had the same Michelin tires on my 72 29' Ambassador for five years and around 25,000 miles without issue. Have fun and enjoy Texas!
Lance
Top is offline   Reply With Quote
Old 03-23-2016, 01:06 PM   #45
Llando88's Avatar
2016 30' Flying Cloud
Hokay, all done at Discount Tire.
It took about an hour to replace all five tires. Five new metal valve stems, 24 new one piece lug nuts, install, warranty, and five date code 1610 Michelin P235/75-15 108xl tires. They ran them to 50 psi. I'll check torque to 110 lbs as we go.
All well headed back to the RV Park, coach felt similar but maybe slightly firmer/steadier? No issues at any rate.
I'll be reprogramming my TST507 sensors for the new set pressure (still +\- 20% though, right?) but I will leave the alarm temp at default (I think it is 158F?).
Just wanted to say 'thanks' to everyone who took time to comment in the thread, and particularly those who PM'd me with help. I deeply appreciate it.
Rich
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 03-23-2016, 09:08 PM   #46
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yup... TST settings sound right. I set my temp at130 in winter... Then 150 in spring thru summer.
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-03-2016, 04:08 PM   #47
Llando88's Avatar
Great, thank you. I'll keep my settings in place.
Towed from San Antonio TX to Leander TX a few days ago, no issues.
Thanks all, much appreciated, again.
Rich
Old 04-08-2016, 11:32 PM   #48
stephenb's Avatar
2011 25' FB Flying Cloud
Hutchinson , Kansas
Maybe this will give you peace of mind. It's from my airstream guru in Canada at can-am.
Hi Stephen
For your Airstream the best tire to use is a Michelin P235/75R x 15" XL (extra load). This tire is rated to carry 50 PSI but 42 is where you want to be with a 25'. We install hundreds of these every year and virtually never have a failure. We are actually just about to change the first test set we put on in 2007. These tires will ride much smoother than your current tires, as well they have considerably more traction especially in the wet. The 16" E range tire is too harsh riding and will cause a lot of movement of things in the Airstream and also contribute to loosened rivets etc. The other bonus is you don't need new wheels.
stephenb is offline   Reply With Quote
Old 05-09-2016, 11:57 AM   #49
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Just a quick FYI to note that in response to my recent (yesterday) inquiry to Michelin on the status / availability of their new Defender LTX M/S 235/75R15 109T XL, they said the following:
"Thank you for your email and your interest in the Michelin Defender LTX M/S tires. Since this is a new tire line some of the sizes are not yet available. Our records indicate that size 235/75R15 will launch on the first week of June. This means that dealers should be able to place an order at that time."
Until then, per Andrew T the existing Michelin LTX/MS2 235/75R15 108T XL will do the job. Only difference I can see is that the new 109T has a slightly higher weight rating.
Rocinante is our 2014 International Signature 27FB
leaky leaky leaky Zellia All Argosy Trailers 8 08-07-2015 05:25 AM
AC replacement-options, options... Belegedhel Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-13-2011 08:54 AM
200 Miles GYM Bulge? GCinSC2 Tires 23 09-08-2010 05:16 PM
My GYM Purchase. $$ Adj. & Valve Stem, The Epilogue GCinSC2 Tires 7 08-08-2010 11:09 AM
Help!! Austin-to-LA-to-Austin Astro On The Road... 13 04-05-2006 10:29 PM
