Old 03-17-2016, 04:30 PM   #29
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by Llando88 View Post
Thanks for the offers of help. At this point we're waiting for the local tire service to arrive to just swap out the spare.
Due to the Rodeo, SXSW and our plan changes, RV sites are impossible to find in Austin.
We booked a week in San Antonio starting tomorrow, so we'll either luck into getting the Michelin swap done tomorrow or we will head to SA with the spare and sort it out down there.
Much obliged all. I will post back when everything is wrapped up and we have a final solution in hand.
Rich
Hope all works out for you!
I was prepared to get you going. There some new Goodyears on Craigslist right now, just up the road from me, in case you just needed 1. I just swapped out to 16" Sendals with Michelin LTX's and still have a new set of 15" rims and Carlisle load range E's sitting in my garage in case we needed to improvise. Airstream central over here
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 03-17-2016, 06:24 PM   #30
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Fix tire , use it for the spare and run the spare, you are good to go...
Old 03-17-2016, 07:01 PM   #31
Ed Brownfield's Avatar
2015 28' Flying Cloud
Charlottesville , Virginia
Congratulations on your new AS! I'm sorry to hear that you are having tire problems. I'll make two suggestions one I am qualified to make the second one I'm not but qualified to make I'll explain. I am a relatively new AS owner myself. We have had to stay over in cities on several occasions due to problems. I have decided that you just have to "bake" problems into your trips and not get too upset about them. I know it's easy for me to say but when I look back at our trip problems they no longer seem so bad. Once we had to stay in TN for five days while AS shipped a new window to an AS dealer in Knoxville to be installed. Now for the unqualified advice, please understand that it is nothing more than my fairly inexperienced opinion. We purchased a 2015 28 FC it came with Marathon Tires. When we were negotiating on the trailer I asked the dealer about switching out the 15 inch Marathon Tires for 16 inch Michelin Tires. He owned the dealership and thought that I should go ahead and do it, he owned an AS and had done it on his own trailer. I think that I read about Michelin 16 inch tires on this forum. I have never regretted making the change I drive with nothing but Michelin on my cars so I trust them. I think that if you switch to Michelin that you should switch all four tires vs. mixing them but check that statement out with a tire expert. Obviously if you go to the 16 inch tire you will have to switch all four tires. Now for more qualified advice ..........breath in.......breath out and enjoy the ride. I hope that you enjoy your AS as much as we are enjoying ours.
Bald Eagle
28 Ft. Flying Cloud
2015 GMC Diesel
Charlottesville, VA
Ed Brownfield is offline   Reply With Quote
Old 03-17-2016, 08:31 PM   #32
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Yes sir; although disappointing, any tire can get a pick up puncture now and then. It's just with the horror stories you read on the GYMs, I was ready to have the tread carcass separate on me driving away from Colonial RV.
Yes, we thoroughly enjoyed our three day stop in SA in our Class B last summer. We've booked 7 days at Traveller's World, same place we stayed before.
Sounds like you've a great plan for continuing the trip despite the tire issue. Awesome!
FYI, here's our blog post about our stay in San Antonio. We stayed in a different place, also nice for a few days.
http://www.casarocinante.com/Blog/Sa...nio-TX-03-2015
Rocinante is our 2014 International Signature 27FB
Old 03-17-2016, 08:43 PM   #33
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
If you go with P rated 15" tires make sure they have the capacity you need. Plenty of threads on this.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 03-17-2016, 09:49 PM   #34
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Something I've not seen mentioned in your thread that could be helpful is the use of leveling blocks used to drive up onto with the good wheel to get the one needing to be removed off the ground.
First loosen the lug nuts a little, then drive up onto the blocks just till the good wheel is on the blocks then remove the offending wheel. No jacking, very stable and safe.
Peters offer is very legit, he is very knowledgeable of airstreams and wonderfully willing to help.
I very much enjoyed stopping in at his place on my first trip in my new to me 345 motorhome on the way from Fla to Az. Mahalo Peter.
Cheers Richard
tevake is offline   Reply With Quote
Old 03-17-2016, 11:44 PM   #35
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Just a thought. You might consider adding Centramatics with your new tire upgrade install. It is not clear how the factory balances the brake drums and hubs, but a set of Centros will keep you balanced going forward. You might even drop by and pick up a set while you are in Texas. Pat
Old 03-18-2016, 05:16 AM   #36
Airstream Driver
1997 30' Excella
Images: 51
Cheers Richard
You are very kind, thank you back to you, Richard. The natives taught you the use of their language well
I even had a set of centramatics for 15/16" trailer wheels laying around. But someone just snatched them up.
1996 Airstream B190
AIR #13
Old 03-18-2016, 05:29 AM   #37
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by Melody Ranch View Post
Take it to a Discount Tire dealer in Austin area. Have the tire fixed and don't make a big deal out of it. SXSW party is still going on in Austin... enjoy the stay.
Originally Posted by 7GenTex View Post
+1
Also, if you want to get a bit away from the SXSW crowds, try:
http://www.riverwayrvpark.com/
just outside of Llano - about an hour or so west of Austin
Or, the State Park in Blanco
http://tpwd.texas.gov/state-parks/blanco
Originally Posted by woodfox45 View Post
Make sure the tire dealer knows how to jack up your Airstream ''''''''
A bigger view:
Bingo
That is not a sidewall puncture.....get it fixed and Stream-0n.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-18-2016, 05:43 AM   #38
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
What he said.
Patch plug and roll on.
Any tire store can fix it.
Just know that 3 years from DOT date is all you'll get.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-19-2016, 12:12 AM   #39
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Oh... if you goop up the inside of your tires, they will ruin the the sensors...
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-19-2016, 04:39 AM   #40
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Switch to the 16" Michelin LT tires. I did it on two previous Airstreams and ordered them on this 2015 we have direct from the factory. AS puts them on the Classics and possible some other trailers now as well. Says something to me at least.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-19-2016, 01:22 PM   #41
Llando88's Avatar
2016 30' Flying Cloud
Stopped in at Discount Tire here in San Antonio, on Goliad Ave.
After looking at my options, I decided to get them to fit 5 new Michelin LTX P235/15 M/S2 XL 108T tires on Wednesday.
I am also getting new metal valve stems (free) and 24 new one piece lug nuts ($3 ea)
This shop has not done too many Airstreams. But they are very busy and have good local ratings. Shop is clean and looks professional.
The only comments I got was what the trailer weight was (7,600 gvwr/3,800 per axle) and that these Michelins would "squat" a bit (?). He also said I'd need to run them at 49 psi (sounds right, 50 psi is what I heard). From what I've read, I 'derate' the Michelin to 1,980#. Times 4 is 7,920#, above gvwr. So weight should be good.
I am going ahead with the Michelin spare also, The Mrs. said 'why not just get rid of all those Chinese tires' so I am good with that also.
If anyone sees any land mines with this, let me know. My appointment is Wednesday morning.
Rich
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 03-19-2016, 02:03 PM   #42
paiceman's Avatar
If it where me and my trailer, and it has been in the past and present. I'd swing for the bleachers and go with 16" on Sendel Wheels. Should not amount to much more than $400 total increase and the 16" will do a better job on weight carrying capacity and subsequently ride of the trailer.
As I posted previously I have done it on a 25' and again on a 30' and ordered them on the 30' we have now when the trailer was built.
Bud
SAFE TRAVELS
Bud
leaky leaky leaky Zellia All Argosy Trailers 8 08-07-2015 05:25 AM
AC replacement-options, options... Belegedhel Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-13-2011 08:54 AM
200 Miles GYM Bulge? GCinSC2 Tires 23 09-08-2010 05:16 PM
My GYM Purchase. $$ Adj. & Valve Stem, The Epilogue GCinSC2 Tires 7 08-08-2010 11:09 AM
Help!! Austin-to-LA-to-Austin Astro On The Road... 13 04-05-2006 10:29 PM
