Old 07-01-2016, 02:15 PM   #1
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Stressing tires with sharp turns
I've read enough about tires (and hitches) here to last me a lifetime. So I thought it would be fun to have another tire thread.
Extremely sharp turns, as in backing up, put a lot of stress on tires as they pivot and grind as opposed to roll. Has there been any discussion here about that? Maybe some of the tire failures are caused by excessive wear due to frequent sharp turns? Maybe some tires are tougher and don't wear as much under those conditions?
Cheers,
John
P.S. I'm trying to get a few more miles out of the Omni Trails (whatever those are) that came with my trailer when I bought it before I switch to Michelins. As a longtime Porsche enthisiast it's hard not to favor Michelins, although I'll probably go with the 15" ones.
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 07-01-2016, 02:50 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yes they scrub in those tight maneuvers, but I'm not so sure it is problematic stress. I do think that's why they no longer do tri-axle models, however. I think Dexter says it's a no-no.
2012 Dodge Durango Hemi/AWD
Old 07-01-2016, 03:02 PM   #3
Images: 59
Wouldn't be a problem if Airstream would switch from tandem axles to single axle/dual wheels.
You could buy those plastic extended fenders like on the old chevy pickups. 8,000 lb Torflex axle with disk brakes should be fine.
Old 07-01-2016, 03:14 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Duals would mean less room inside or a skinnier coach to stay within the 8'6" max width.
I will take tandem axles over dual tires any day. Single axle trailers tend to sway more than tandems.
TG Twinkie is online now   Reply With Quote
Old 07-01-2016, 04:07 PM   #5
1991 25' Excella
Stanfield , Oregon
Mine leaves some nice tire marks backing it into my driveway.
SpletKay06 is offline   Reply With Quote
Old 07-02-2016, 11:57 AM   #6
1977 31' Sovereign
Lynnwood , Washington
Trailer tires, together with spindles, are engineered to work "in tandem" to flex laterally.
What's important is that you not park with tires in "flexed" position. So before you park and "call it a day", roll your rig a few forward and/or backward so tires (and spindles) can straighten themselves out.
Tom
TomKirk is offline   Reply With Quote
Old 07-02-2016, 03:03 PM   #7
1967 26' Overlander
Spartanburg , South Carolina
Cheers,
John
That is precisely why ST tires are made with stronger sidewalls and my reason for running only GYM's on my 26' Overlander.
Jacob D is offline   Reply With Quote
Old 07-02-2016, 04:23 PM   #8
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
Because of the pivoting action, it is much easier to back a tandem axle trailer than a single axle trailer. The single axle unit will roll around a point thus taking much more room to turn. In our business we deal with all kinds of truck and trailer situations. Never heard of it being a problem.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN, Greenest State in the Land of the Free
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 07-02-2016, 04:25 PM   #9
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
That's why you inflate the tires to max. Shown on the sidewalls; to give them some support in flexion.
MelGoddard is offline   Reply With Quote
Old 07-02-2016, 08:34 PM   #10
1996 25' Excella
Tillsonburg , Ontario
Bottom line: ST tires are made to handle that..Not so sure about LT tires
JCW
JCWDCW is offline   Reply With Quote
Old 07-02-2016, 09:11 PM   #11
Anna Maria , Florida
Yup, they do have Super Beefy sidewalls unfortunately they forget to glue the threads on the same beefy way. My sidewall was like new when the thread peeled of and beat the crap out of the side of our Airstream.
And that is my reason for never ever running GYMs on our trailer again.
franklyfrank is offline   Reply With Quote
Old 07-02-2016, 10:32 PM   #12
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Frank, what year tires did you have that failed. There were a number of the mid 2000s era ST tires that did have problems. GYMs were among trailer tires that had a number of failures then. I thought, however that from approx 2010 and later those ST problems had been corrected. In fact I wonder if any one has real data that covers ST tire reliability for the last 5 years or so.
Howard L. is offline   Reply With Quote
Old 07-03-2016, 02:37 PM   #13
yuppie cowboy
2012 30' Classic
Star , Idaho
Smile Stressing tires
Ever notice how big rigs often have lift axles. Beyond scrubbing the tires you also break the bands (you don't realize it until later) then you have a catastrophic tire failure with a perfectly good looking tire. As a riveter I am also a owner of over the road trucks and semi trailers, and this is a all to common very expensive problem. Just imagine cranking your A S over a curb on a tight turn maybe while parking or getting out of a place you should not have been.
larrykling1 is offline   Reply With Quote
Old 07-03-2016, 04:31 PM   #14
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Agreed... and why I replaced our GYMs with GYMs when they were due for changing at 5 years of age, 4 years ago and they're still fine.
Additional info: "A marathon experience".
SilverGate is offline   Reply With Quote
Bottom drawers coming out in sharp turns Millionsaver Sprinter and B-van Forum 29 03-25-2016 04:22 AM
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
Sharp Turns: Blowout Cause? John&Vicki Tires 39 07-09-2015 08:41 PM
Key Turns and Turns..is this normal? help shiny1973 Doors & Locks 10 11-25-2008 04:57 AM
