Old 03-31-2019, 10:09 AM   #1
2012 25' FB Flying Cloud
albany , Georgia
Storage of tires off ground.
I am considering raising my 25 footer off ground between trips. Anyone used four automobile scissor jacks then helping maintain balance support with the four feet and front hitch ?
So someone out there must have a system that they like and use, input please.
Cheers,
James.
jmpgino is offline   Reply With Quote
Old 03-31-2019, 10:26 AM   #2
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Scissor jacks tend to not be very stable. You should consider using 6 ton jack stands and a bottle or floor jack to raise the trailer up.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 03-31-2019, 10:28 AM   #3
2007 22' International CCD
Or the combination jack stand and bottle jack. You only really need two of them. The tongue jack can easily hold up the front end.
Old 03-31-2019, 10:36 AM   #4
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 121
Just this morning I jacked my trailer up so there is about a 1/4" clearance for my new GY Endurance tires to stay off the ground, also taking pressure off the axles. I used 4 jack stands, 2 just in front of the forward wheels, and 2 just behind the rear wheels on the jacking points. (4 all together) I also covered the tires with reflective wheel covers I bought online. The sun here in Tampa cooks the tires. I pulled off an old set of tires and wheels and there was a flat spot on the bottom of the tire after only a few months of sitting in the sun.
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 03-31-2019, 10:39 AM   #5
dznf0g's Avatar
Oswego , Illinois
I use 4 jack stands and a bottle jack between the axles to raise. I usually only lift off the ground if it is going to be more than a couple months between trips. Now that I am retired and planning winter trips, I doubt it will be a couple months between trips now. The issue is the rubber rods being compressed for extended periods and taking a set. They like to be exercised frequently to remain pliable (like tires). My understanding is that compression will accelerate the hardening and potential cracking of the rubber.
-Rich-
Old 03-31-2019, 10:44 AM   #6
Land of Oz
1970 25' Tradewind
Pittsfield Twp , Michigan
I always have my TV attached when jacking trailer for stability, don't trust my tongue on blocks while raising one side at a time. Just a piece of mind thing.
Raising tires is a good idea for long term storage considering reputation of trailer tires. I kept the old rims/tires when I upgraded so I throw them on for winter storage, putting my good set in the garage.
wizardglass is offline   Reply With Quote
Old 03-31-2019, 12:57 PM   #7
albany , Georgia
Been searching around. Two of these sound like they would work. I would have to check them periodically but for the price they look like they would do the trick. I am a serious welder for fun and thought of producing something on my own but for the price and to just get the tyres off the ground, this may be my best bet.
What do you think chaps ???
https://www.amazon.com/Alltrade-6409...gateway&sr=8-3
Old 03-31-2019, 01:07 PM   #8
albany , Georgia
On second thoughts, after further reading the jacks above have issues. So this set looks like my next best option.
I have a 25 ft that is always stored dry, I am thinking two 3 ton jacks would be more than sufficient, these 6 ton ones seem overkill ??? Am I right or wrong ???
Old 03-31-2019, 01:23 PM   #9
When it comes to jacking up something and possibly working under it, massive overkill on the jack stands is just good sense.
My setup is rated to support the total weight of the Airstream with just one. Not that Iím paranoid or anything, but crush injuries are thought to be painful. Better safe than dead, IMHO.
Old 03-31-2019, 01:28 PM   #10
dznf0g's Avatar
Oswego , Illinois
Well I have 4 ◊ 6 ton stands under mine, so......... I like the very wide base stance on higher rated stands.
-Rich-
Old 03-31-2019, 01:34 PM   #11
Mine have a wide stance, and a steel plate on the bottom. Keeps them from digging holes in asphalt or soft ground.
Old 03-31-2019, 03:15 PM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Cheers,
James.
Two 5ton jack stands & the tongue jack...17 Seasons no problems. Saves the axles & tires.
Lift on the axle frame mount.👍 For storage only.
ID:	337024   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 04-01-2019, 10:11 AM   #13
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Why?
No need unless we are talking years in storage.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 04-01-2019, 11:09 AM   #14
dznf0g's Avatar
Oswego , Illinois
Originally Posted by cazual6 View Post
Why?
I disagree, but that's OK.
Years in storage is cumulative for compressed rubber degregation, not consecutively starting over each time it is moved. So mine has had 50 months in storage + the time in-season between trips. Sounds like years to me.
-Rich-
Jacking both tires off the ground questions.. Estrange Tires 17 05-18-2017 08:20 PM
Off The Ground Storage Aquabud Winterizing, Storage, Carports & Covers 2 09-17-2011 12:24 PM
How High to Lift Wheels off Ground? Roadrunner Wheels, Hubs & Bearings 16 03-16-2010 03:09 AM
Wheel comes off ground or lack of axle movement jasper2222 Axles 11 09-24-2007 06:16 AM
