Old 12-25-2007, 06:21 AM   #15
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We are about to get a set of Pressure Pros after our three blow-out debacle of last spring. Are there any tips on where to buy, how to install, whether or not to include the TV tires, etc.?
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 12-25-2007, 06:25 AM   #16
lewster's Avatar
Naples, FL , Hood River, OR
MT,
You can get them from Overlander 68. I would do all of your tires on the trailer and TV if you are going to make the investment. Installation is very simple ad straight forward.
Old 12-25-2007, 06:29 AM   #17
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Brian, I think your Suburban has TPM already installed. When the pressure in one tire drops 12 psi or more below the others, a funny-looking yellow half-tire with an exclamation point lights up. You can push the little "i" button on the dash or steering wheel, and scroll through the menu usung the little button with the white squares on it to access the info. It should show actual pressures on all 4 wheels, the spare does not have a sensor.
Old 12-25-2007, 08:39 PM   #18
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Moosetags...it's actually "68 Overlander" (not "Overlander 86") who sells the PressurePro Sensor systems...We got ours from him not too long ago...I called and had them within a week. Our Tacoma has a factory sensor system so we didn't order them for the truck but if it didn't have it already, we would have gotten or the truck as well. We like them very much so afar...
TB
TB & Greg and Abbey Schnauzer
#3954
Old 12-26-2007, 05:11 AM   #19
lewster's Avatar
TB
TB,
Randy is 'Overlander 68'.
Old 12-26-2007, 12:49 PM   #20
New Borockton , Alabama
Images: 21
We have not had any reports to date of a stolen sensor. The Lock-nuts will keep the honest people away and do work but probably only about 50% of people buy them.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 12-26-2007, 01:05 PM   #21
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Originally Posted by lewster
TB,
Sorry...but it is "68 Overlander"...see post #20...
TB
#3954
Old 12-26-2007, 04:28 PM   #22
lewster's Avatar
I must be having a dyslexic kind of day!!!!!
Old 12-26-2007, 08:51 PM   #23
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Heh-heh...no harm done...I've truly had my share of those!
TB
#3954
Old 12-27-2007, 06:12 PM   #24
airstreamhobo's Avatar
stolen Pressure Pros
You can buy locks for the Pressure Pro System also for a small cost. I usually leave it up to the customer if they want them. About half my sales have included locks with the order. I was told that some were stolen on the New Foundland Caravan by kids that thought they were novelities and tossed them into the ocean nearby. AirstreamHobo
AirstreamHobo
Lancaster Co. Pa.
1999 28' Excella
Ford Diesel Van "The Obie Van"
WBCCI #2590
TAC PA-2
http://airstreamhobo.blogspot.com/
airstreamhobo is offline   Reply With Quote
Old 12-27-2007, 10:31 PM   #25
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Pressure Pro Source
Brian,
I bought mine (after reading about your eventful trip) at the International in Perry last June. This was the dealer PressurePro Tire Pressure Monitoring System TPMS Pressure Pro
Installation was very easy. Finding a place in the truck for the panel was harder. I finally ended up buying the visor clips. It works up there very well. One thing I discovered on our trip last October was when you do the morning pressure check and find a tire needing air, unplug the monitor panel before you remove the pressure sensor from the tire. If you don't, you have to reset the whole thing, as it will show no sensor for that tire.
I remove my sensors when Daisy is going to sit for more than two weeks. They will be back on next week as we head up to the Can Opener. See you there. Oh, and so far no thievery. You really can't see them on the trailer wheels unless you look closely, and I didn't put them on the truck, but might some day.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 12-28-2007, 12:12 AM   #26
JDL
JDL's Avatar
2005 19' International CCD
T , Oregon
I have some too. Love them. I would reccomend them to anyone who tows.
JDL is offline   Reply With Quote
Holding Tank sensors andyfuson Waste Systems, Tanks & Totes 43 01-09-2009 10:16 PM
original tank sensors goransons Fresh Water Systems 4 07-20-2007 09:25 PM
Tank Sensors Dan G. Waste Systems, Tanks & Totes 47 07-19-2007 06:05 AM
Holding Tank Sensors seamusthegray Waste Systems, Tanks & Totes 7 11-08-2004 03:38 PM
Level sensors - not working drboyd Waste Systems, Tanks & Totes 3 12-06-2003 07:16 AM
