Old 08-16-2007, 08:33 PM   #1
millvalleyca's Avatar
2008 27' International CCD FB
Mill Valley , California
spare tire question
I have to call road side assistance to change a flat on my Airstream.
Will the spare under my A frame be the same as my other four tires? (wheels and rims?)
I'm going to hitch the trailer to my truck and roll the good tire over some boards to raise the trailer so the tire can be changed. Anything else I have to do?
Thanks!
millvalleyca is offline   Reply With Quote
Old 08-16-2007, 08:44 PM   #2
Retired.
. , At Large
Thanks!
The spare is the same size and brand as the rest of your tires, although it is probably on a steel wheel instead of an aluminum wheel. Loosen the lug nuts slightly before rolling the trailer onto the boards, the auto club guy can unscrew them easier up in the air if the nuts have been loosened.
Old 08-16-2007, 08:47 PM   #3
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
Thanks!
One other thing... Don't let the roadside assistance guy jack up your trailer by the axle!
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 08-16-2007, 08:48 PM   #4
Retired.
. , At Large
Yes, that could ruin your weekend--and your axle.
Old 08-16-2007, 09:14 PM   #5
Thanks guys for the fast response.
Have you ever heard of a faulty tire that leaks? or more likely that I ran over a nail or similar item. It is the rear tire.
Old 08-16-2007, 09:38 PM   #6
Sorry...almost forgot
I'm using the "lego" clip together risers. They're about an inch high. How high do I have to raise the good tire in order to remove the flat tire?
Old 08-16-2007, 09:42 PM   #7
Roadtoaster's Avatar
2019 30' Classic
Byhalia , Mississippi
Not real sure but I think my "drive on" jack is about 4 inches tall.
Greg
Roadtoaster is offline   Reply With Quote
Old 08-16-2007, 10:06 PM   #8
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
The lego things work great to raise the good wheel. It takes three to get the bad tire clear. I speak from extensive experience (3 flats on one trip). If you get the tire up without loosening the lug nuts, no problem. Just have your partner manually apply the trailer brakes. It is usually better not to let some moron from AAA change a tire on an Airstream. He will most likely end up punching a hole in the bottom of the trailer or bending the axle.
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 08-17-2007, 10:55 AM   #9
Thanks Moosetags
I've been debating on whether or not I should change the tire myself......never having changed a tire before is it better to have the paid moron do it or myself? Will I be able to get it tight enough? The last guy that changed my car tire stood and jumped on the lug wrench to tighten it. (yes AAA guy)
Say I do do it myself.....what are the correct steps to take?
I guess I should learn at some point!
Old 08-17-2007, 11:53 AM   #10
Cos
1973 21' Globetrotter
Middletown , Rhode Island
Why can't a trailer be jack up by the axle - you can't put a floor jack under one end near the frame to jack it up?
Cos is offline   Reply With Quote
Old 08-17-2007, 06:59 PM   #11
1984 31' Excella
Broken Arrow , Oklahoma
Images: 11
Jacking
The reason for not putting the jack on the axle is because you stand a very good chance of destroying the axle.
These torsion axles are a different lot.
It is far far safer (and easier) to loosen the lug nuts and pull the good wheel up on blocks thus lifting the flat tire wheel off the ground.
These airstreams have specific jacking points. If you use the blocks, you don't have to remember where the points are.
Beginner
Beginner is offline   Reply With Quote
Old 08-17-2007, 07:23 PM   #12
zamboni's Avatar
"break" loose all lug nuts on the flat wheel. drive onto your boards. set iTV in park & parking brake and chock other side wheels front and back. finish removing the lug nuts, leaving the top one for last. remove flat tire & wheel. Install new (hopefully inflated, you'd better check that before removing from the A-frame) install all lug nuts hand tight, then slightly tighten w/ lug wrench in a star pattern, then snug them up w/ wrench. remove wheel chocks, back off boards, put TV in park & parking brake on, tighten (torque) all lug nuts on changed tire in star pattern, then clockwise pattern. Check air PSI in all tires on AS, check tight lug nuts on all wheels of AS, put away flat tire and tools...get tire replaced ASAP. JMTCW
zamboni is offline   Reply With Quote
Old 08-17-2007, 07:48 PM   #13
Retired.
. , At Large
Could be a nail, bad valve stem (we got a whole case of 'em--talk about return visits), even a defective aluminum wheel, or cracked steel wheel.
Old 08-17-2007, 08:14 PM   #14
Thanks Zamboni (related to the smooth ice family?)
Seems simple enought....I"ll give it a try tomorrow.
Would you "fix" the bad tire or simple replace? Will most good tire shops carry the tire size for my Airstream?
Dennis
Old 08-17-2007, 08:22 PM   #15
Retired.
. , At Large
Dennis
As long as the tire has not been "run flat" or run low on pressure (evidence is a groove worn on the outside of the sidewall, and runner shavings inside the tire), and the hole is not too large, it can be repaired. With a patch, not a plug, and with the tire guy rebalancing the tire, not marking the locations of the wheel weights with a crayon, and hammering them back on. the best I have seen is called a "patchplug", that fills the hole made by the nail, and covering the hole on the inside as well.
Old 08-17-2007, 08:26 PM   #16
moosetags's Avatar
Thanks Moosetags
Get a Sears torque wrench and do it yourself. You'll know it's done right.
Old 08-17-2007, 08:44 PM   #17
TankerIP's Avatar
2002 22' International
2019 25' Flying Cloud
Using a Jack?
The owner's manual for my 22' AS says there is a jack plate welded underneath. Many on the forum have said to not use a jack. What about using this jack plate? Dare I try this?
Maunual Quote:
"To CHANGE A TIRE with a jack see the
label affixed to the underbelly to the rear of
the wheels. This label, says JACK with an
arrow and points to a plate riveted to the
mainframe rail where the jack head must be
placed. A flat tire may also be changed
without the aid of a jack. Drive the unit up
on a ramp 8” wide, 6” high, and about 3 feet
long at its base. Position the good tire on the
ramp. This will raise the flat tire clear of the
ground."[IMG]file:///C:/DOCUME%7E1/Papa/LOCALS%7E1/Temp/moz-screenshot-2.jpg[/IMG]
TankerIP is offline   Reply With Quote
Old 08-17-2007, 09:41 PM   #18
thanks Moosetags
questions/answers sure lead to more questions.
which torque wrench to buy? Kragens 45.00 - Sears (up to) hundreds of dollars!!
How many pounds of torque are we talking about?
Old 08-17-2007, 09:56 PM   #19
Sorry for the dumb questions
like this one?
Craftsman 44600 Tire Torque Wrench, 1/2 in. Square Drive at Sears.com
Old 08-17-2007, 11:08 PM   #20
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
That will more than do the job
Fyrzowt is offline   Reply With Quote
2003 International AS Pahaska 2002 - 2005 International 149 10-01-2017 06:38 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Where to mount spare tire 74SovereignInt. Tires 26 11-27-2002 10:00 PM
Tire code info FrankR Tires 1 05-20-2002 09:18 AM
Tire Pressure thenewkid64 Tires 1 03-31-2002 01:44 PM
