Old 05-30-2015, 01:13 PM   #1
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
Spare Tire Mounting Bracket help
I am wanting to build a Mount for the Spare Tire and could use a little help with what it should look like. I am moving the Propane Rack forward enough to allow for this mounting arrangement on my '58 AS Traveler.
Pictures would be greatly appreciated.
thanks in advance!
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 05-30-2015, 06:49 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi prairie schooner, I don't know if this is helpful. My 66 Trade Wind had this "J" shaped steel member riveted to the front of the trailer. The spare tire sat in the bottom of the J. I bolt was threaded through one of the lug holes of the wheel.
Here is a photo. I don't have one of just the spare tire carrier. Maybe someone else has a photo of theirs. It is made of steel about 3/16 thick. It had a cross piece toward the top. There were pop rivets holding the thing on, as well as sheet metal screws down at the front plate area.
Judging from the corrosion of the front skin, I'd say that spare tire carrier was dealer mounted when new.
David
Name:	1309 Exterior Spare Tire.jpg
Old 05-30-2015, 07:45 PM   #3
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
FYI, there is a thread that discusses a spare tire holder similar to what you are showing on this thread. Someone build the holder from scratch and posted these pictures. I was very impressed and saved the pictues for future reference in case I was to do the same thing.
Name:	Spare tire holder.jpg
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 05-31-2015, 08:24 PM   #4
1958 18' "Footer"
thanks guys! the last one is very interesting indeed! I was thinking of using something that would come out of a receiver but the pivoting one is a much better idea,
I haven't found the link yet so any help would be appreciated, thanks again guys both are helpful!!
Steve
Old 05-31-2015, 09:48 PM   #5
1974 Argosy 20
Kooskia , Idaho
Here is a photo of my Argosy Spare Tire. It simply fits in the A frame against the front of the trailer and is held in by the gas tanks. It sits there by gravity, nothing holds it other than friction. There is no mount whatsoever. Been there for the 16 or 17 years I have owned the rig.
Old 05-31-2015, 10:58 PM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Tire carrier
The person posting the thread about the tire carrier in the photos above is Onawayman here on the forums. He built it from scratch and says it works well. I will return here and post the thread name for you. Ed
The thread is listed as: Tongue Mounted Spare Tire Carrier. If you put it into the search box above on the blue tool bar it should direct you to his post. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 06-01-2015, 07:11 AM   #7
1958 18' "Footer"
I found the post for that;
http://www.airforums.com/forums/f438...-106407-2.html
This looks like it will work out well for me. Some discussion about the weight issue on the tongue but it should be better than on the rear and not enough clearance underneath.
Mine will be polished so I want a bracket to keep it away from the skin.
thanks again!
Steve
Old 06-01-2015, 08:55 PM   #8
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
Airstream offers a bracket/kit that goes under the front frame. I have it on my 1978 Argosy and gives you more space on the A frame to use an LP cover. Angy at Inland RV has it. Part # 10989
Argy 78 is offline   Reply With Quote
Old 06-01-2015, 11:05 PM   #9
1958 18' "Footer"
Do you have a pic of it installed? still not sure about the ground clearance with it but a pic may help. Thanks
Steve
Old 06-02-2015, 05:23 AM   #10
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Tire carrier
Here are a few pics of the current Airstream spare tire carrier.
https://www.facebook.com/26805399654...type=3&theater
Here is the older "J" version remade with aluminum.
Lance
Top is offline   Reply With Quote
Old 06-02-2015, 05:51 AM   #11
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Spare Tire Mounting
I needed to increase tongue weight and free up some "trunk" space so I moved my spare tire to the tongue. I thought about mounting it behind the LP tanks but that would have involved relocating LP lines, etc so I chose a simpler solution. The cross bar is aluminum channel and the vertical bolts are galvanized. Ground clearance is 9 inches and has not been a problem so far.
ID:	239811   Click image for larger version
BambiTex is offline   Reply With Quote
Old 06-02-2015, 07:40 AM   #12
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
My setup is identical to BambiTex's. I created mine 6-7 years ago and have had no clearance issues.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-02-2015, 08:12 AM   #13
geezernbabe's Avatar
1970 31' Sovereign
Rogue River , Oregon
I got a spare tire mount off of a small truck at a dismantler and put it in the frame then cut out the belly pay so when you turn the shaft it goes up into the frame about half way. Lots of clearance and low cost. There is some welding to do but not much. Been awhile for pics but here goes.
geezernbabe is offline   Reply With Quote
Old 06-02-2015, 03:25 PM   #14
1958 18' "Footer"
Thanks for the help guys!
I do not have enough ground clearance to install the spare under the tongue and really don't want to remove any of the original belly pan.
Top's pictures answered my original question yet not sure that I want to add anything to the front of my Traveler simply because of leaks, etc.
I still like the idea of the spare mounted behind the propane tanks and upright. This will at least resemble what might have come originally. The pivoting bracket may be the answer and it could be removed easily with no issues. I am replacing the copper propane lines anyway so I'll just do that after I get a mount built. Next I need to get the wheel I picked up on CL painted and down America's Tire to mount the 7-14.5 tire I bought last year.
Thanks again for all of the advice on this it has been very helpful in making my decision.
Steve
16" spare tire vs OEM spare tire rack Bluto Wheels, Hubs & Bearings 22 04-30-2013 05:13 AM
LCD TV Mounting Bracket - One More Question flyfisher Audio, Video & TV 99 03-17-2013 07:26 PM
Spare Tire Mounting question polarlyse Tires 5 05-05-2011 07:31 AM
Spare Tire bracket optional? Jared129 Wheels, Hubs & Bearings 3 05-14-2008 09:38 AM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
