Old 06-02-2015, 04:58 PM   #15
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
The spare tire carrier bracket fits flush with the floor between the A frame as it goes back into the trailer behind the front windows. Sorry I don't have any pictures but I saw it in the forums. As I mentioned go to Inland RV and look up part # 10989.
Be safe and enjoy each day to its fullest!
Argy 78 is offline   Reply With Quote
Old 06-22-2017, 11:00 AM   #16
1967 22' Safari
Elkton , Maryland
Thumbs up Thank you!
Thank you so much for posting your solutions WITH pictures. I'm in the same situation with my '67 Safari.
We normally store it in the trailer while towing and under the trailer when parked. It's heavy and my hubby won't be able to lift the tire this season due to his recent bicep surgery. It's too heavy/cumbersome for me to lift.
I think that I'm going to use idroba's solution and stick it behind the propane tanks and have a spare tire cover for it (in silver in our case). I'll just take the additional step of securing it to the tongue with a chain. If there is any space between the tanks/tire/trailer front then I'll just add some padding (old pillows?) inside the tire cover.
Thanks again for your solutions!
Amanda
NJ Amanda is offline   Reply With Quote
Old 06-23-2017, 08:08 AM   #17
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
I must have forgotten to post my solution on this. From my restoration page;
I used 1 1/4" square tubing & then some 1/4" x 1" flat stock and all held in place with lug nuts. The lug nuts mean that I will have a couple of spares and the wrench needed to change a tire. It is real simple and looks like it will work nice.
I did have to move the LPG rack forward a little to make some room but still have room for the jack to work.
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
16" spare tire vs OEM spare tire rack Bluto Wheels, Hubs & Bearings 22 04-30-2013 05:13 AM
LCD TV Mounting Bracket - One More Question flyfisher Audio, Video & TV 99 03-17-2013 07:26 PM
Spare Tire Mounting question polarlyse Tires 5 05-05-2011 07:31 AM
Spare Tire bracket optional? Jared129 Wheels, Hubs & Bearings 3 05-14-2008 09:38 AM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
