Old 10-16-2014, 07:29 PM   #1
2014 27' Flying Cloud
Wenatchee , Washington
Spare Tire Mount Question
I've installed my Sendel T02/Michelin LT225/75R16E tires on our '14 Flying Cloud 27FB (and the take-offs are going on the SOB I'll be selling soon, so they're going to a good home). Anyway, my question is which way should I mount the spare tire, shiny side up or down (or does it matter)? I needed the spare on our maiden voyage last month and I really didn't pay attention to the way it was mounted by the factory.
I decided to go with the stock aluminum wheel that matches the ones on the ground. (FWIW, I did a search before posting this but was unable to locate the answer.) Thanks!
2012 Ram 3500 CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is online now   Reply With Quote
Old 10-16-2014, 07:49 PM   #2
SteveH's Avatar
Common Sense , Texas
I like to mount them shiny side down so I can crawl under there with an air hose to check the air pressure and adjust if needed without having to remove the spare from the mount.
Do it before every trip just to be on the safe side.
Regards,
Steve
Old 10-17-2014, 02:26 AM   #3
Smile
That makes good sense, Steve. I plan to carry one spare tire in the stock position (underneath the trailer) and another in the bed of my tv. I just don't think you can be too safe.
This tire upgrade gives me a lot of piece of mind. Our tire speed rating has increased from 65 to 106 mph (and with speed limits of 75-80 in the wide open spaces out West, this is important to us).
I ordered the Sendel wheels, Michelin tires, and McGard lug nuts based on the information I gleaned from Airforums and everything fit perfectly. Thank you all for taking the time to post your lessons learned to help your fellow Airstreamers, and I hope to see you on the road.
WBCCI #7180
Old 10-17-2014, 06:50 AM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
As previously stated, I vote for shiny side down for ease of access to the valve.
Also, I would counsel against towing at 75 to 80 MPH even if the speed limit allows it and you are using LT tires rated to 106 MPH. Take your time and arrive safe.
Bob Martel
WBCCI# 5766
Old 10-24-2014, 06:18 PM   #5
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
And did you consider Centramatics to minimize vibration? They dynamically balance the entire hub/wheel/tire assembly.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 11-02-2014, 08:23 PM   #6
Got 'em ordered. Of course, I've already installed the 16's but you live and learn.
WBCCI #7180
Old 11-02-2014, 08:41 PM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I just mounted the new 16" spare on my 25FB yesterday. I mounted it shinny side down to be able to access the valve stem. That is the way that the 15" OEM spare was mounted.
Brian
SuEllyn & Brian McCabe
Old 11-02-2014, 09:45 PM   #8
Thanks.
WBCCI #7180
16" spare tire vs OEM spare tire rack Bluto Wheels, Hubs & Bearings 22 04-30-2013 05:13 AM
spare tire mount Judy Barde Wheels, Hubs & Bearings 5 06-12-2008 07:59 PM
Front spare tire mount walter1 Tires 4 10-07-2004 11:05 AM
Where to mount spare tire 74SovereignInt. Tires 26 11-27-2002 10:00 PM
