Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 04-15-2008, 04:55 PM   #1
1953 Flying Cloud
1953 Flying's Avatar
Profile:  1953 21' Flying Cloud
Sacramento , California
Images: 8
Spare Tire holder
Hi all,
After searching for a while I have come up with nothing. This past weekend I discovered that I need to add more tongue weight to my trailer. Here is what I have
Trailer weight dry- 2940 Lbs
Tongue weight - 150 Lbs
My TV Dodge Durango, 4.7, 4 x 4
TV weight with 1/2 tank gas and me is 5200 Lbs
As far as I know the tongue weight should be about 10 to 15 percent of the trailer weight.
So here is my question. To add more weight to the tongue I wanted to add my spare tire to the undercarrige of the tongue. I can't seem to find one. Has any one else done this or have any ideas where to by it?
Thanks for the help again,
_______
Robert
Life is like a roller coaster, a whole lot of up's and down's..
1953 Flying is offline   Reply With Quote
Old 04-15-2008, 04:58 PM   #2
OregonArgy's Avatar
Profile:  1978 Argosy Minuet 6.0 Metre
Gresham , Oregon
I've heard of people installing it vertically between the LP tanks and the body of the trailer.
So...you bought a vintage trailer, did you, honey? Good deal, was it? Oh, just a couple of repairs, huh?
Drat, now our little Argy is starting to grow on me. I guess you were...were...were...right, honey.
OregonArgy is offline   Reply With Quote
Old 04-15-2008, 05:01 PM   #3
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
I've seen one on a mid 60's Safari. You can put twin 30# LP tanks up front as well, and mount your battery (if you have one) under the front couch. Every little bit helps. The above will add about 60 pounds to the tongue.
Another option is to emulate Airstream when they added weight inside the tongue to increase tongue weight to some of their trailers.
You repair things with tools. You fix things with a hammer.
AIR#2611
Old 04-15-2008, 05:12 PM   #4
1953 Flying Cloud
Images: 8
Quote OregonArg-I've heard of people installing it vertically between the LP tanks and the body of the trailer.
I've seen this also, if the bracket get loose it rubs on the aluminum and make a mark. Plus it hides the shine in the front.
I have now 2- 5# propane tanks and a 25 gallon water tank up front. Which helps a lot. I was just trying to figure out another spot to put my spare instead of the inside of my TV since I can add more weight to the tongue.
_______
Robert
Old 04-15-2008, 05:15 PM   #5
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Where is your battery, can you move it forward? We are putting a spare tire mount under the front of our Liner, just like Airstream has. Do you have enough room between the frame rails for a spare tire?
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Old 04-15-2008, 05:27 PM   #6
1953 Flying Cloud
Images: 8
Bill
My batteries are located in the rear trunk. So can't not move those. I do have enough room under the front tongue area.
_______
Robert
Old 04-16-2008, 05:38 AM   #7
CJ 1969 Soveriegn 31'
Profile:  1969 31' Sovereign
Alex , Oklahoma
Check this one out.
1972 27
Hope the web sight come through. Someone on the forum "Sneakinup" posted this 7-4-2005.
1969 Sovereign 31'
AIR #18751
CJ of Okla is offline   Reply With Quote
Old 04-16-2008, 04:27 PM   #8
1953 Flying Cloud
Images: 8
Originally Posted by CJ of Okla
Check this one out.
1972 27
Thanks CJ,
Thats exactly what I'm looking for. I guess I can try to fabricate one. Wish me luck.
_______
Robert
Old 04-16-2008, 05:21 PM   #9
geezernbabe's Avatar
Profile:  1970 31' Sovereign
1970 23' Safari
Shingle Srings , California
Hi Robert nice to meet you at Cassini. I do not have the pics handy but I got one of the crank up tire winches off of a mimi van I think it was. It was real easy to mount and cranks the tire right up to the bottom of the sub floor. If you would like to come up and look at it PM me and we can work it out were only 1/2 hr away. Dave & Penny
geezernbabe is offline   Reply With Quote
Old 04-16-2008, 05:49 PM   #10
urbanfood's Avatar
Profile:  1956 22' Flying Cloud
Venice , California
hi robert,
i believe you're looking for this.
boy oh boy! my new '56 flying cloud!
that's my '56 flying cloud. they are available from airstream i believe (same that they put on the new ones i've been told).
i had greg at inland rv put one on when he was doing the axle work.
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 04-16-2008, 06:52 PM   #11
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
my 2001 has it mounted in the front under the body between the frames. A nice simple leaver pulls it up and a collar lockes it in place. No tools needed! A clever, simple device. It should be readily available at Airstream, and cheaper than fabrication in the long run.
Keep the shiny side up.
WBCCI # 3485
Region 3 2nd VP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 04-16-2008, 07:21 PM   #12
1953 Flying Cloud
Images: 8
Originally Posted by urbanfood
hi robert,
David your progress on your FC is awsome. Regarding the tire holder does it go up into the underbelly or is it completely under the aluminum on the outside? I have already redid my underbelly and would hate to cut a hole to make that bracket fit.
I really don't want to fabricate one as of my welding skills are not so hot.
_______
Robert
Old 04-16-2008, 09:09 PM   #13
urbanfood's Avatar
Venice , California
the tire holder goes up into the underbelly and allows the tire to site inside the triangle 4" frame and just under the subfloor. it hangs down below the frame a few inches. so no i will not have a bellypan in that area. you would have to cut your belly pan to install it but i think it'd be worth it.
i agree about buying versus making it. the cost was less than $200 and it was once less thing i hade to make so i was happy to purchase it.
david
Old 04-17-2008, 01:05 AM   #14
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
Robert, did you see my spare location when we were at Casini? It's up under the propane tanks..half under the front of the coach. I can take a picture and post it for you. It cost me almost nothing....but then I have a lot of junk to create from.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar:
Wright's Lake
California.
1966 Trade Wind
455 cid
Pingbacks are On
Spare Tire Holder Question 63Safari Wheels 12 08-19-2006 12:43 PM
Spare tire BB 55 Bubble Tires 11 04-08-2006 07:45 PM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Spare tire for 65 GT muddy_hollow Tires 2 12-29-2004 06:32 PM
Rear tire holder tandemfish General Motorhome Topics 5 11-27-2004 11:08 AM
SEO by vBSEO 3.1.0
