Old 09-23-2012, 11:07 AM   #1
L911's Avatar
1971 18' Caravel
Cookeville , Tennessee
Images: 12
Spare tire for a '73
Hi, I have a 1973 AS Ambassador 29' (built in 70') with 6 lug/15" rims. Currently I dont have a spare, my tow vehicle is a 2000 Suburban that uses a steel 6 lug/16" (similar in actual height) can i use it as a spare for my trailer as well?
L911 is offline   Reply With Quote
Old 09-23-2012, 11:10 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Check the offset and the bolt circle diameter.
Old 09-23-2012, 11:24 AM   #3
The wheel rating should be a minimum of 2600 pounds.
Wheels take a huge beating when used on a tandem or tri-axle trailer.
Everytime you make a turn, those wheels received tremendous side pressures.
Make a turn in a parking lot and stop the rig, while in that turn. Look at how much the tires are twisting. That is what applies those side forces.
Just because a wheel may fit, does not make it useful, unless it's proper rated, except in an absolute emergency, where caution and safety are tossed to the wind.
For short distances, in fact you don't need a spare, as your Airstream will handle just fine at low speeds, with only 3 tires in use.
Old 09-23-2012, 12:07 PM   #4
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
Question
What does this mean?
How could it be?
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 09-23-2012, 12:37 PM   #5
How could it be?
What's the serial number.
What your quoting, only happens to a stolen trailer, that's re-identified.
Old 09-23-2012, 12:39 PM   #6
Post a side view photo and a serial number.
Only stolen trailers have mixed up ID's.
Old 09-23-2012, 03:24 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You will need the correct weight capacity as well, to make sure the wheel can handle the stresses of towing, like twisting and turning, as well as carrying the load.
Old 09-23-2012, 04:38 PM   #8
L911's Avatar
1971 18' Caravel
Images: 12
We call it a 73' cause the inlaws bought it then.....my bad.
Old 09-24-2012, 04:48 AM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
How could it be?
Some states use the year the title is issued versus the model year of the vehicle. Makes for some real fun and games 30 years down the road.
Aaron
WBCCI #XXXX AIR #2495
Spare Tire - Life Expectancy Frank&Mike Tires 23 11-22-2011 03:28 PM
Spare tire carrier under rear end. perryg114 Tires 21 11-02-2011 12:34 PM
Need spare tire rim for size 700-15 1976 has alum mag wheels Caravanner76 Wheels, Hubs & Bearings 3 10-18-2011 09:21 PM
Spare Tire Mounting question polarlyse Tires 5 05-05-2011 07:31 AM
Spare Tire Holder vhariable 1974 - 1979 Sovereign 1 04-08-2011 03:09 PM
