Old 12-29-2004, 03:16 PM   #1
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
Spare tire for 65 GT
I have a J-bar-cross tire holder that was on my 65 GT. I'm told it was original and had at one time an aluminum cover. The tire was in the way of my weight distribution system so I have taken it off. As the tire holder was steel, it corroded the skin. So I'll buff that out. no big deal.
What I'd like to get an opinion, or several, is could I mount the tire on the rear bumber as I have seen others do? What are the drawbacks other than looks? Also, anyone know where I can find a tire cover made of aluminum?
Doug
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 12-29-2004, 04:15 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Doug!
Doug
Based upon the experience with my '64 Overlander, I would definitely advise AGAINST adding the spare tire carrier to the rear bumper. My Overlander had its spare tire mounted on the rear bumper for much of its life - - the result was rear end separation and repair expenses of just under $2,000. I detest having to carry the spare in the tow vehicle, but at least for the time being, that is where I carry the spare for the Overlander (there is insufficient room for the front tongue mount with 40 pound LP tanks).
Beyond the potential of contributing to the development of rear end separation, I would also avoid the rear bumper position on a single axle coach to avoid subtracting weight from the hitch.
With my Overlander, the plan is to have one of the modern, under-coach mount spare tire carriers adapted for the purpose. I kept my 20 pound LP tanks on the Minuet so that I could add the behind-the-tanks spare tire mount when I have the exterior restored (the Minuets used a very similar spare tire mount to the one found on your GT).
Good luck with your research!
Kevin
Kevin D. Allen
AIR #827
Old 12-29-2004, 06:32 PM   #3
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Kevin's advice is sound as usual. Adding weight to the rear end is an invitation for trouble.
What kind of weight distribution do you have which prohibits tongue mount of the spare?
I'm attaching a pic of the spare tire mount on my former '71 Caravel. Very simple but effective and no contact with the skin. It did not interfere with the Reese hitch I was using. I'd recommend this type of mount if your trailer tongue will accomodate it.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Where to mount spare tire 74SovereignInt. Tires 26 11-27-2002 10:00 PM
Spare tire storage mysilverbullet Our Community 9 10-23-2002 10:35 AM
