Old 11-01-2011, 09:37 AM   #1
1981 31' Excella II
New Market , Alabama
Spare tire carrier under rear end.
Would it cause a disturbance it the Airstream Force if I put a spare tire carrier under the rear of my trailer where there is lots of room since it is a center bath model it is relatively unloaded compared the the rear bath models? I picked up a spare rim and tire for $106 at a local trailer place. I don't know that I would run it full time but it beats the heck out of running on three wheels. It came with a D rated 225/75-D15 trailer tire.
Next question is where to find a carrier or do I need to make one.
Perry
Old 11-01-2011, 10:08 AM   #2
sandlapper's Avatar
1993 34' Excella
York , South Carolina
It would be low, might drag it off, especially on a 31'. Front would be better. Ours is up in a "well" at the front end, in a carrier. If you don't have the well, back of the TV may be best bet. John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 11-01-2011, 10:11 AM   #3
Perry
Don't do that.
The ground clearance will go south.
Spare tire carriers already exist, that fit very neatly underneath the front end of the trailer, and made by Airstream, that do not change the ground clearance.
Old 11-01-2011, 10:48 AM   #4
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you don't have the one in front, it's relatively easy to install. Most Airstream dealers sell the carrier, all you would have to do is cut the belly pan between the A-frame and front crossmember, and put the aluminum up against the floor and bolt the carrier in place. Yes, the crossmembers already have the threaded holes in hem.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 11-01-2011, 01:50 PM   #5
1981 31' Excella II
Well the same clearance problem will exist if the tire is located in the front will it not? Either way you have to remove the skin and make a pocket for it to fit in. The skins are already off in the rear right now and that is the reason I want to put it back there. I can't see it sticking down much below the original skin level. The tire would fit almost all the way to the floor between the beds.
Perry
Old 11-01-2011, 02:35 PM   #6
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 36
I Wouldn't Do It
I am surprised Andy didn't mention the risks associated with hanging anything that far aft on a vintage 31.'
There is no frame to speak of back there. The floor is literally supported by the shell, I believe.
A heavy spare that far back could cause frame separation and tail droop.
Imagine the floor as a long lever arm, with the fulcrum at the axle. Every jolt and jar would be tearing the floor assembly from the shell.
Let's see if Andy will confirm, or deny, this observation.
P.S. I've seen folks destroy their Airstreams by attaching big storage boxes and generator storage racks to their rear bumpers.
Ken L
1966 Tradewind 24
2018 GMC Yukon XL Denali
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 11-01-2011, 02:47 PM   #7
Mounting anything on the rear? HECK NO, PERIOD.
The spare tire mounted in the front, cannot possibly lower the front clearance, since the tire itself, sits on a platform, that pushes the tire against the bottom of the interior floor.
The underbelly is cut out within the A-frame. That metal is then fastened to the bottom of the floor. Sealing with Vulkem is a must.
When done correctly, if the font of the tralier is on the ground, without a jack, you still cannot touch the tire carrier with the ground.
Old 11-01-2011, 03:18 PM   #8
Well Preserved
1993 21' Sovereign
Perry
The spare is supposed to go at the A-frame. The tongue jack base and WD brackets will be torn off before the spare tire carrier contcts the ground.
Old 11-01-2011, 03:47 PM   #9
1981 31' Excella II
Mine is an 81. I have a full box beam and no bathroom and no holding tanks back there. I am probably 1000lb lighter back there than the rear bath models with the same frame. The 70's model 31's had just a single C-Channel beam instead of a full box beam. It was just an idea guys.
Perry
Old 11-01-2011, 05:37 PM   #10
1975 31' Sovereign
Opelika , Alabama
it would be fine, since you have the belly skin off already, just make a bracket out of some old angle iron and weld it between the frames. btw, i see you are in new market. i am in opelika.
ps. some of these guys are a little intense. i think some of them might be yankees. i was at desoto s.p. last week, it was ok but too many people.
bobnmary is offline   Reply With Quote
Old 11-01-2011, 05:55 PM   #11
sandlapper's Avatar
1993 34' Excella
Do yourself a favor, buy the carrier,mount it under the front, out of the way, could even help with tongue weight.
ps. South Carolina was the first state to succede from the Union (and the first to sign the Declaration of Independence)
John
Are you kind?
Old 11-01-2011, 06:08 PM   #12
2004 30' Classic
Hillsborough , New Jersey
tire carrier
you mean "secede" !! wolf146
wolf146 is offline   Reply With Quote
Old 11-01-2011, 06:10 PM   #13
1973 31' Excella 500
Marysville , Washington
Um, I'd be slow to ignor the advice of those with over 10,000 posts and have essentially made their careers around Airstream.
Not Done is offline   Reply With Quote
Old 11-02-2011, 04:39 AM   #14
sandlapper's Avatar
1993 34' Excella
Wise man once said, " If you're gonna be stupid, ya better be tough"
John
Are you kind?
Rear End Separation Permanent Fix? dmand001 Repairing/Replacing Floor &/or Frame 23 07-24-2017 02:12 PM
How does my rear end look? desertair27 Repairing/Replacing Floor &/or Frame 35 02-23-2013 11:24 PM
Spare Tire Carrier Installation How To? woodfox45 General Repair Forum 1 08-14-2011 10:30 AM
Suggestions for a spare tire carrier? NicheVintage Tires 5 04-28-2011 10:59 PM
Parts needed - 345 Spare Tire Cover on rear, et.al. audiv8q Exterior Restoration Forum 0 02-24-2011 02:33 PM
