Old 02-11-2006, 06:26 PM   #1
sigv's Avatar
1963 24' Tradewind
Pittsford , New York
Spare tire - best way to handle
Just purchased 63 tradewind (first trailer). Where did AIrstreams originally have the spare tire? I have seen some trailers on eBay with the tire mounted on he back - is that a customization or did they come from the factory like that?
Any suggestions / information appreciated!
-Sig
sigv is offline   Reply With Quote
Old 02-11-2006, 06:45 PM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I keep mine in the bed of the tow vehicle. Not a good idea to keep spare on the back of the coach, due to rear frame seperation issues.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-11-2006, 06:51 PM   #3
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Red face Spare Tire
Hi Sig,
On my 1985 Sovereigh I gave up trying to mount the spare tire. All I do now is trow it in the back of the pickup which has a camper shell on it. I feel that AS felt that with 4 tires we may not need a spare and could limp in to repair station. Good luck about the repair station when you are heading to Alaska or far west. The repair stations are far and few.
I used my spare 3 times so far for one reason or other. Mostly becouse one my axels was bent. We blamed the brake locking up.
So if you have a pick up tow whecle just trow it in the back.
Regards Russell In Sunny Tucson Az.
RUSSELL is offline   Reply With Quote
Old 02-11-2006, 07:00 PM   #4
bill benton's Avatar
Mansfield , Texas
Airstream makes a spare tire carrier for its newer trailers that fits under the tongue,behind the propane bottles. I believe it was made for its newer trailers. There might be a way to adapt it to your tradewind
bill benton is offline   Reply With Quote
Old 02-11-2006, 07:30 PM   #5
Larry71's Avatar
Allentown , New Jersey
Send a message via Yahoo to Larry71
Hi Sig,
I have a 1971 Safari and my spare tire is mounted under the frame of the trailer in the front end of the trailer. I had assumed that this was standard on older AS's. Fortunately I have never had to use it and I hope it stays right where it is. Good luck with your new rig.
Larry
Larry71 is offline   Reply With Quote
Old 02-11-2006, 07:40 PM   #6
_
isn't the '63 tradewind on smaller wheels or with less ground clearance than the newer trailers?...seems this would be an issue with the front/under tire carrier?
cheers
2air'
Old 02-11-2006, 10:23 PM   #7
gotair's Avatar
Send a message via MSN to gotair Send a message via Yahoo to gotair
spare tire in front
I found that there is room on mine in front between the trailer and gas tanks
here is a picture
Name:	july 05 029.jpg
Life's short...take your kid camping
gotair is offline   Reply With Quote
Old 02-11-2006, 10:30 PM   #8
gotair's Avatar
by the way those propane bottles were stollen and the new replacements are on and the tire still fits fine. there is not alot of room under my trailer to mount a spare but that sounds like another location to look at maybe yours has more ground clearance than mine... my brother has another brand and his spare is in front...between the frame rails like a spare on a pickup..? what ever you chose good luck and I would try to have a spare with me somewhere
Old 02-11-2006, 10:39 PM   #9
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
My spare is right behind the propane tanks just like gotairs'. It is outta the way there and I can lock it and the propane tanks up all at once. Plus I don't have to remember to throw it in when packing for a trip.
Chris
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 02-12-2006, 06:23 AM   #10
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Chris
That is where the spares were located for a long time. There are brackets for this, so the tire won't rub the shell.
Old 02-12-2006, 06:43 AM   #11
till's Avatar
Lisle , Illinois
Images: 108
Here is the factory option under the floor spair carrier. I like this because it is out of the way.
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 02-12-2006, 07:12 AM   #12
sigv's Avatar
1963 24' Tradewind
Originally Posted by Larry71
Hi Sig,
Larry
I like the idea of having it on the trailer. My 63 does sit low however but we are going to have GSM replace the axle and (from my understanding, the trailer will sit consirerably higher with a new one). I will contact CSM and see what they can do. Will follow up with the forum and let you know what we decided to do.
Old 02-23-2006, 07:30 PM   #13
1976 25' Caravanner
Campton , New Hampshire
I installed mine as per AS instructions in Service Manual , with a few modifications. I didn't want to loose all the floor insulation so I sandwiched a piece if 1" urethane between the plywood floor and the alum shielding(cut from belly pan). I also covered the exposed A frame with alum., then caulked all seams to make water tight . Some angle iron and bolts will make a fine carrier , don't really need AS parts . When wife returns (Florida) I'll try to get some pics , she has the camera. Took about a day , most of it plannig , you know how these one-off's are.
ticki2 is offline   Reply With Quote
Old 02-23-2006, 07:35 PM   #14
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
What? Carry a spare tire? Where's your spirit of adventure? (Nope, we don't carry a spare.)
Lynn
WBCCI 21043
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Where to mount spare tire 74SovereignInt. Tires 26 11-27-2002 10:00 PM
Spare tire storage mysilverbullet Our Community 9 10-23-2002 10:35 AM
