Originally Posted by pmclemore
Are you sure 65psi is the right pressure for your bambi? Sounds more like a pressure for a heavier trailer.
Pat
This is a single axle trailer. So the load per tire is greater than most multi-axle trailers.
65 PSI, I think that is a load range "E"? Not sure.
Having a fully loaded spare is the only way to go. Otherwise you would need ot find a source to inflate the tire (like a
12V air compressor that was stated above) Because a flat or low spare doesn't usually work.
>>>>>>>>>>>>Action
