Old 07-07-2003, 07:31 PM   #1
Lost My Rivets
jdleezer's Avatar
2013 30' Classic
New Braunfels , Texas
Spare Tire?
I'm a new member and I also just purchased a 1969 Overlander which seems to be in very good condition.
After purchasing the trailer and driving the first 200 of the 950 mile trip back home, I realized there wasn't a spare tire on the trailer, and there isn't a location for a spare tire. I guess that is why I didn't realize it inititially. I got lucky and made it home without incident. But now after reviewing several photos of airstream trailers, I notice there normally isn't a spare tire on Airstream trailers, or is there and I'm just not seeing them?
John
jdleezer is offline   Reply With Quote
Old 07-07-2003, 07:38 PM   #2
Chas's Avatar
Images: 22
Welcome friend,
They mount under the floor directly behind the propane tanks. You should see a "well' where it fits. The spare tire and carrier was an option I believe and it can be added to yours. I don't have one on my Overlander either. I think you can actually pull the trailer (at low speed) with a flat tire? You may have to remove it though. Some advantage they tout of having the independent Duratorque axle. Maybe I need to read up on my manual?
Chas
Chas is offline   Reply With Quote
Old 07-07-2003, 07:51 PM   #3
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Spare tire
You can remove the wheel with the flat and tow at low speed. However, like you, I live in Texas where it may be 100 miles to the nearest flat repair and 200 miles to the nearest replacement tire, For that reason, I installed a spare carrier and spare tire on my trailer. Chas is correct about the location.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 07-07-2003, 07:58 PM   #4
Lost My Rivets
jdleezer's Avatar
2013 30' Classic
I didn't notice a "well" but I'll check for it tomorrow morning. So I'm guessing you pull your trailer without a spare tire. I guess if I had a owner's manual the spare tire (or lack of one) would be discussed. Do you know where to get old Airstream manuals? In addition to the spare tire, or lack of one, there are several other things I like to know about my trailer. The previous owner went over most applications (I didn't take notes), but now that I'm home with it, I'm having a hard time recalling them.
John
Old 07-07-2003, 08:45 PM   #5
Spare tire - adding
My 70 Globetrotter came from PO w/o spare. Oasis RV in Tucson added the well just rear of the tanks by cutting out the underpan, raising the cutout to the bottom side of the floor plywood, sealing the whole thing with Vulcem. The tire carrier then bolted in and by jove it looks just like them fancy factory installations. A little pricy, but she's my baby...
Bruce Campbell
Dillon, CO
'70 Globe Trotter 21'
BruceACampbell is offline   Reply With Quote
Old 07-07-2003, 08:53 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
On many Airstreams the "well" is not there. A spare tire was not a normal factory option on the 2001 Safari line. You will find no recess in that location. I made a special request for a spare at build time and the recess was built in at the factory.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-07-2003, 09:49 PM   #7
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We have a spare tire bracket on the front tongue of our GlobeTrotter
A spare tire bracket was a $50 option in '64. And a 6-ply tire & wheel were another $56.25 or 8-ply was $62.50. Although we've not seen another one like it...it appears to be very original and an integral part of the tongue.
Tongue without the spare in place:
With the spare:
Shari
Old 07-08-2003, 05:59 AM   #8
Chas's Avatar
Images: 22
Good lookin' tire carrier Shari,
I guess I am lucky? I indeed do have the "well" for a spare and even the threaded bolt locations for the bracket. I also have a brand new spare tire and wheel that I kept when selling my Argosy so I guess a proper spare and location are not far off.
Anyone know if the bracket is still available?
Will the new brackets fit on my 74?
Chas
Old 07-08-2003, 06:25 AM   #9
Lost My Rivets
jdleezer's Avatar
2013 30' Classic
I don't have the "well" for the spare tire. I guess the easiest fix would be to add the spare tire bracket behind the propane tanks. I would have to move the propane tanks forward to make room. Thanks for the photos Shari.
John
Old 07-08-2003, 12:57 PM   #10
InsideOut's Avatar
1956 22' Safari
Images: 108
Only if it's a tandem axle...
Shari
Old 07-08-2003, 01:53 PM   #11
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I had the same problem, so a friend built me a mount to put it in front of the propane tanks. He welded it into place and it's solid as a rock. There's just enough room to turn the crank on the jack, and I think it looks pretty good there with the cover on it.
Stephanie
Old 07-08-2003, 02:35 PM   #12
My spare is mounted directly to the front of the trailer. The factory mounted a large "hook," (like a picture frame hook, but about 5" wide) under the front window, and the tire sits on that. An aluminum cover covers the tire. I believe that this was part of the International package that year.
Another factory alternative was a rear bumper mounted spare, like a continental kit for a '56 T-bird. There is an example here:
www.vintageairstream.com/archives/61FC/61FC.html
63flyingcloud is offline   Reply With Quote
Old 07-08-2003, 06:53 PM   #13
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Spare Tire?
The factory may have offered rear bumper mounted spare tires in the very early sixties, but the dealer installed unit on my '64 Overlander caused more than $1,750.00 in damage. After nearly forty years of that spare bouncing along on the rear bumper, the coach developed a case of rear end separation - - the cure was to remove the rear bumper mounted spare and install a set of suspenders or galluses that re-attached the rear frame to the body of the trailer.
I didn't believe the warnings about this feature as it had always been with the coach since it was new. In the end, I am paying a big price for not heeding the warnings about maintaining a spare mounted in that position.
I know that the preferred placement for the spare on my coach was on the tongue behind the propane tanks so that may be in the coach's future as having the spare rattling around in the back of my tow vehicle is getting VERY old.
Kevin
Kevin D. Allen
AIR #827
Old 07-08-2003, 08:21 PM   #14
Lost My Rivets
jdleezer's Avatar
2013 30' Classic
Thanks for all the responses. Sounds like if you have a tandem axle model Airstream, a spare tire isn't a necessity (you can drive short distances with a flat to get repairs). I'm glad I didn't get a flat between El Paso and Junction on I-35 towing the trailer home. I still think it is a good idea to have one, I'll just move that down on my to-do-list.
If one did have a flat and a spare, where are the jacking locations for a 1969 Overlander (under the axle of the flat tire?)? Boy, I wish I had a owners manual.
John
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Spare Tire Carrier Pahaska Our Community 8 08-27-2003 09:00 AM
Spare Tire Cover ALANSD Airstream Motorhome Forums 8 07-27-2003 11:55 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
