Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 07-08-2003, 10:03 PM   #15
Tikihut
Tikihut's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
schaumburg , confusion
I put a bumper mount on my Argosy
Tikihut is offline   Reply With Quote
Old 07-08-2003, 10:08 PM   #16
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
John,
The Dura-Torque Axle allows a four wheel trailer to be towed on 3 wheels for up to 100 miles at no more than 30 mph according to my manual. I experienced a blown rear curbside tire about 45 miles west of Amarillo, TX. with subsequent sheetmetal and outrigger damage. I towed at 40 mph but was careful of irregularities in the road like potholes so that my exposed disc rotor was not damaged.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-08-2003, 11:12 PM   #17
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Boy, I wish I had a owners manual.
You can get photocopies of owners manual (1964+) and service manuals (1972-1986) from:
Helen Davis Secretarial Services
PO Box 484 Sidney, OH 45365
(937)492-8885
Prices are about $33 and $70 respectively.
Shari
Old 07-09-2003, 10:11 PM   #18
Forrest
Forrest's Avatar
Profile:  1966 20' Globetrotter
1986 32' Excella
Aurora , Colorado
Images: 21
Owners manual
There is an owners manual for a 66 Overlander at the VAC web site. I know yours is a 69, but there may be useful information never-the-less. There are also a number of service bulletins you may be interested in too. Here is the url:
http://www.airstream.net/members/doc....html#tmanuals
Forrest
Forrest is offline   Reply With Quote
Old 07-10-2003, 08:22 AM   #19
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
I think it was John Irwin that also pointed out that the factory mounted spares under the front need some shims to stop the rattles so that weld failures don't happen. It could have been Jack that pointed that out too, but at any rate if you have the under front spare, you should look into bracing it a bit better to avoid movements.
Eric
Old 07-10-2003, 08:38 AM   #20
74SovereignInt.
74SovereignInt.'s Avatar
Profile:
Previous Thread
JDLeezer, you might want to view this previous thread. Several members were good enough to provide photos in response to my question. There are some good ones of the undermount type. I think that the bracket is available although one could certainly make one themselves without much trouble. Good Luck.
http://www.airforums.com/forum...&threadid=2615
74SovereignInt. is offline   Reply With Quote
Old 07-10-2003, 08:44 AM   #21
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Original thread
Eric
My original post shows how I installed a foam block to keep the spare from bouncing in the carrier.
Spare tire weld failure
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 07-10-2003, 08:50 AM   #22
Silvertwinkie
Aluminut
Nice. Thanks for reposting John.
Eric
spare tire? Chas Tires 14 07-04-2005 08:09 PM
Spare tire winch wanted mcneon Parts Archive 6 03-05-2004 06:21 PM
Spare Tire Carrier Pahaska Our Community 8 08-27-2003 10:00 AM
Spare Tire Cover ALANSD Airstream Motorhome Forums 8 07-27-2003 12:55 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 05:40 PM
