Old 05-20-2008, 02:18 PM   #1
1970 31' Sovereign
Apple Valley , California
Spare Tire
We have not been able to find where the spare tire is supposed to go and how is was attached to a 1970 Land Yacht Soverign. We're in the learning process. Thank you, Beverly
Beverly II is offline   Reply With Quote
Old 05-20-2008, 03:08 PM   #2
brownsmtnlab's Avatar
1970 31' Sovereign
Greeneville , Tennessee
Images: 8
You might have been expected to travel without one.( the owners manual intimates that) Our 1970 did not come with a carrier either. I have constructed a carrier that accepts a compact temporary use spare, that fits just behind the propane tanks. It took a while to find the proper rim/tire combo with a proper load rating. I believe it came from an early '90s nissan truck product of some kind. A standard spare would not fit in that location without a great deal of modification. Given a few days I could come up with a picture for you if your interested. Others have constructed carriers that hide in the underbelly near the front of the coach...I have seen pictures on this forum, but I couldn't tell you where.
Kevin
If you don't know where you're going, any road will take you there
brownsmtnlab is offline   Reply With Quote
Old 05-20-2008, 03:54 PM   #3
1953 Flying Cloud
1953 Flying's Avatar
1953 21' Flying Cloud
West Sacramento , California
Images: 8
I had a similar question. Here is the response I received.
http://www.airforums.com/forums/f438...der-41271.html
Custom driver license Pet ID's.
www.petidforme.com/105
1953 Flying is offline   Reply With Quote
Old 05-20-2008, 07:34 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
70s Airstreams had the optional spare stow flat under the floor between the tounge A frame. Some owners have retrofitted a carrier which involves cutting away that section of belly pan and finding or making a hinged support bracket. You should be able to find this if you search past threads. With tandem axles you can tow slowly on 3 wheels. I don't now have a spare, but if I get one I will just throw it in the back of my pick up.
Old 05-20-2008, 08:11 PM   #5
1994 30' Excella
Mississauga , Ontario
Airstream makes a spare carrier that mounts as Lumatic says. They use it on the new trailers. Not sure if that would fit your model year.
Al
Old 05-20-2008, 09:00 PM   #6
1968 30' Sovereign
Belleville , Ontario
Hello there! My 30' 1968 Sovereign stores the spare tire flat under the front of the trailer behind the A-frame - kind of under the living room sofa. It's lowered by a handle that is raised just behind the propane tanks... if that's any help. Just take a look under the front of your's to see if you have that spot in the underside of the floor - maybe you're missing the bracket or could make something.
Regards, Ryan
menormy is offline   Reply With Quote
Old 05-30-2008, 08:48 PM   #7
1964 24' Tradewind
Bell Canyon , California
Images: 51
I have the same problem. I am searching for a design I once found showing how to make a spare tire carrier behind the propane tanks on the tongue of the trailer. Any luck finding a design or remedy for the spare tire problem, so many of us have.
fzgrab is offline   Reply With Quote
Old 06-02-2008, 04:20 PM   #8
1970 25' Caravanner
Grand Junction , Colorado
i just have a copy of the manual, do you know the rim size for a 1970 caravanner/25 ft., i have been quoted 15 x6, 6 on 5.5 with 4.25 PH
rattan is offline   Reply With Quote
Spare tire. mrmossyone All Argosy Trailers 7 12-25-2007 08:19 AM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Spare tire for 65 GT muddy_hollow Tires 2 12-29-2004 06:32 PM
Spare Tire DEO 2005 Safari 9 06-01-2004 03:46 PM
Spare Tire? jdleezer Tires 21 07-10-2003 07:50 AM
