Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 10-10-2002, 02:48 PM   #1
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
Unhappy spare tire?
Does anyone have an idea where Airstream mounted the spare tires ( if offered) on their units? Specifically on mine, a 78 Argosy Minuet? I have seen a few which had it mounted on the rear bumper but always thought this was a definite no-no as I am already battling a minor degree of rear end separation as it is. ( Yes Andy, I swear I will get my wheels balanced) I thought about moving the LP tanks forward a bit and building some sort of tire cradle that I can slide the tire into from the curbside. It woiuld have to be off-center as I need room to access the fresh water tank door. The tongue is short as it is. Yes, it would be a squeeze. Maybe lengthen the tongue? Carry a can of Fix a Flat? Keep throwing the spare in the bed of my pickup???
Chas is offline   Reply With Quote
Old 10-10-2002, 03:00 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
The newer models have the spare underneath the front of the trailer, but there is a factory provision for it in the banana wrap.
I have seen spare tires mounted behind the propane bottles, even under the propane bottles on some trailers.
I am battling the same thoughts. Maybe someone has a better suggestion??
Uwe
Old 10-10-2002, 03:20 PM   #3
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
my 73 has a cradle under the front of the trailer. No spare, though...I can only assume this is what its for. I'll take a pic and post it tomorrow...
Old 10-10-2002, 03:52 PM   #4
53flyingcloud
53flyingcloud's Avatar
Profile:  Amherst , New Hampshire
Talking info:
I asked the same question this past summer while at the A/S factory and, I was told that they will sell you a "spare tire" mounting kit. It's installed under your Airstream just behind the A frame. I didn't ask about the price because upon looking at one already installed, IMHO..I didn't like the looks of it.
Having said that, I should say why..It looked to me that, this would leave the underneath exposed to the weather/rain from driving, etc
I wished I had taken a picture of it..Maybe someone out there will post one..
ciao
Chuck, just read your post..That would be nice if you could post the pic...
53flyingcloud is offline   Reply With Quote
Old 10-10-2002, 04:31 PM   #5
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Under "A" frame mount circa 1965.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 10-10-2002, 04:35 PM   #6
BobbyW
BobbyW's Avatar
Houston , Texas
Picture 2
-BobbyWright
-BobbyW AIR# 123
-Red Green
Old 10-10-2002, 05:26 PM   #7
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Bobby.
Is that a split ring wheel your using for a spare??
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 10-10-2002, 06:49 PM   #8
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Our '64 has it mounted on the a-frame behind the propane tanks. I don't know if it was a retrofit or not, my guess is "not" as everything else on the trailer is/was original unmodified equipment.
Shari
Old 10-10-2002, 07:06 PM   #9
BobbyW
BobbyW's Avatar
Houston , Texas
You win Andy, but sorry, no prize. I was hoping sombody would notice that and post it. The tire and wheel are long gone. The rack, thanks to MarilynW, has been all cleaned up is now a shiny silver, along with the rest of the front frame.
-BobbyWright
-BobbyW AIR# 123
-Red Green
Old 10-11-2002, 06:59 AM   #10
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I just throw mine in the back of the truck, that way I'll never need it. You only need the spare if you leave it at home! The person I bought mine from bought a new rim and tire for a spare. He told me it was a "special" rim only used on Airstreams. Well, it fits my RidgeLane flatbed trailer too, so now I have a spare for that also!
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 07-04-2005, 09:25 AM   #11
Jerry West
Profile:
Does anyone know where I can get a spare trie bracket for an 2002 Bambi, used is good.
Jerry West is offline   Reply With Quote
Old 07-04-2005, 09:34 AM   #12
Ferroequine
Ferroequine's Avatar
Profile:  1975 23' Safari
Calgary , Alberta
Our spare is mounted in a bracket underneath the body, just behind the A frame.
When we first decided to replace the tires last year (they were new, in good shape when the trailer was purchased a few years earlier), we pulled the spare out as well to check on the thread condition. Lo and behold, the spare was a 5 lug pattern, P rated tire! The regular mag wheels are a 6 lug, LT rated tire (single axle). I wonder if the PO even realized this when he sold the trailer, or if he pulled a fast one. Good thing that there were no flat tires for the first two years...
1975 Safari 23'
2004 Ford Expedition Eddie Bauer 4x4
Ferroequine is offline   Reply With Quote
Old 07-04-2005, 05:06 PM   #13
JMR
Profile:
Hi Ferroequine,
I'm currently in the process of finding new wheels and tires for my 65 GT. Where in Calgary did you find replacement wheels & tires? Was there much of a selection? And if you don't mind me asking what was the $$?
I've gone down to the local Fountain Tire and all they said they could replace my rims and tires with were the standard "white" trailer rim. Quoted me a price of $485.00 for two, wheels and tires, balanced etc.
Jeff
JMR is offline   Reply With Quote
Old 07-04-2005, 05:27 PM   #14
Sneakinup
Master Riveter
Sneakinup's Avatar
Profile:  1972 27' Overlander
. , Mobile-- as in transient
Images: 72
This is what I did for mine. I built it out of angle steel.
Spare Tire Carrier
1972 27' Overlander 72 Overlander
Jack Pad--- A notebook used by Jack Nicholson in the Shining to keep track of how much work he had done on his Airstream. "All work and no polishing makes Jack's Airstream a dull trailer"
Sneakinup is offline   Reply With Quote
Spare tire winch wanted mcneon Parts Archive 6 03-05-2004 05:21 PM
Spare Tire Carrier Pahaska Our Community 8 08-27-2003 09:00 AM
Spare Tire Cover ALANSD Airstream Motorhome Forums 8 07-27-2003 11:55 AM
Spare Tire? jdleezer Tires 21 07-10-2003 07:50 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
