10-10-2002, 02:48 PM
Austin
spare tire?
Does anyone have an idea where Airstream mounted the spare tires ( if offered) on their units? Specifically on mine, a 78 Argosy Minuet? I have seen a few which had it mounted on the rear bumper but always thought this was a definite no-no as I am already battling a minor degree of rear end separation as it is. ( Yes Andy, I swear I will get my wheels balanced) I thought about moving the LP tanks forward a bit and building some sort of tire cradle that I can slide the tire into from the curbside. It woiuld have to be off-center as I need room to access the fresh water tank door. The tongue is short as it is. Yes, it would be a squeeze. Maybe lengthen the tongue? Carry a can of Fix a Flat? Keep throwing the spare in the bed of my pickup???
10-10-2002, 03:00 PM
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
The newer models have the spare underneath the front of the trailer, but there is a factory provision for it in the banana wrap.
I have seen spare tires mounted behind the propane bottles, even under the propane bottles on some trailers.
I am battling the same thoughts. Maybe someone has a better suggestion??
10-10-2002, 03:20 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
my 73 has a cradle under the front of the trailer. No spare, though...I can only assume this is what its for. I'll take a pic and post it tomorrow...
10-10-2002, 03:52 PM
1984 29' Sovereign
Savannah
, Missouri
info:
I asked the same question this past summer while at the A/S factory and, I was told that they will sell you a "spare tire" mounting kit. It's installed under your Airstream just behind the A frame. I didn't ask about the price because upon looking at one already installed, IMHO..I didn't like the looks of it.
Having said that, I should say why..It looked to me that, this would leave the underneath exposed to the weather/rain from driving, etc
I wished I had taken a picture of it..Maybe someone out there will post one..
ciao
Chuck, just read your post..That would be nice if you could post the pic...
10-10-2002, 04:31 PM
1965 20' Globetrotter
Houston
Under "A" frame mount circa 1965.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
10-10-2002, 04:35 PM
Houston
Picture 2
-BobbyWright
BobbyW
AIR# 123
10-10-2002, 05:26 PM
Corona
Bobby.
Is that a split ring wheel your using for a spare??
inlandrv.com
airstreamparts.com
10-10-2002, 06:49 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Our '64 has it mounted on the a-frame behind the propane tanks. I don't know if it was a retrofit or not, my guess is "not" as everything else on the trailer is/was original unmodified equipment.
Shari
10-10-2002, 07:06 PM
Houston
You win Andy, but sorry, no prize. I was hoping sombody would notice that and post it. The tire and wheel are long gone. The rack, thanks to MarilynW, has been all cleaned up is now a shiny silver, along with the rest of the front frame.
-BobbyWright
BobbyW
AIR# 123
10-11-2002, 06:59 AM
Moderator Emeritus
1972 31' Sovereign
High Springs
I just throw mine in the back of the truck, that way I'll never need it. You only need the spare if you leave it at home! The person I bought mine from bought a new rim and tire for a spare. He told me it was a "special" rim only used on Airstreams. Well, it fits my RidgeLane flatbed trailer too, so now I have a spare for that also!
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
07-04-2005, 09:25 AM
Does anyone know where I can get a spare trie bracket for an 2002 Bambi, used is good.
07-04-2005, 09:34 AM
Our spare is mounted in a bracket underneath the body, just behind the A frame.
When we first decided to replace the tires last year (they were new, in good shape when the trailer was purchased a few years earlier), we pulled the spare out as well to check on the thread condition. Lo and behold, the spare was a 5 lug pattern, P rated tire! The regular mag wheels are a 6 lug, LT rated tire (single axle). I wonder if the PO even realized this when he sold the trailer, or if he pulled a fast one. Good thing that there were no flat tires for the first two years...
07-04-2005, 05:06 PM
Hi Ferroequine,
I'm currently in the process of finding new wheels and tires for my 65 GT. Where in Calgary did you find replacement wheels & tires? Was there much of a selection? And if you don't mind me asking what was the $$?
I've gone down to the local Fountain Tire and all they said they could replace my rims and tires with were the standard "white" trailer rim. Quoted me a price of $485.00 for two, wheels and tires, balanced etc.
Jeff
07-04-2005, 05:27 PM
1977 31' Sovereign
Tampa Bay
This is what I did for mine. I built it out of angle steel.
Spare Tire Carrier
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
07-04-2005, 07:09 PM
1972 25' Tradewind
Willis
spare tire
I am looking into a setup using a cable crank like trucks and vans use. I will have to wait until I remove one at work to see one out of a vehicle. I will mount it under the a frame with access behind the lp tanks, hopefully.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Spare Tire Carrier
Pahaska |
Our Community |
8 |
08-27-2003 09:00 AM |
Spare Tire Cover
ALANSD |
Airstream Motorhome Forums |
8 |
07-27-2003 11:55 AM |
Spare Tire?
jdleezer |
Tires |
21 |
07-10-2003 07:50 AM |
Z71 or Z85?
River Rat |
Tow Vehicles |
7 |
05-09-2003 04:40 PM |
