Old 11-16-2004, 09:46 AM   #1
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
Spare tire?
Wanted to know
1)If you have a spare for your trailer? (maybe silly question)
2) Where do you keep your spare?
thanks!
Abe
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
vajeep is offline   Reply With Quote
Old 11-16-2004, 10:29 AM   #2
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Based on my experience, a spare is always a good idea.
On a single axle trailer, a spare tire is not something I would leave home without. Tandem axles can limp along ok on 3 tires until you get to a tire shop if you're willing to take that risk.
The best location for the spare is on the tongue, if you have room. Second best is underneath the front although a bit of a PITA to get to. Spares should never be mounted on the rear of the trailer.
Of course a spare might be carried in the tow vehicle, but I prefer to keep it mounted on the trailer for convenience.
A can of Fix-a-flat is an inexpensive but handy item to carry in your tool box.
That's my story and I'm sticking to it.
Rog
May you camp where wind wonít hit you, where snakes wonít bite and bears wonít git you.
Rog0525 is offline   Reply With Quote
Old 11-16-2004, 11:31 AM   #3
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
While Fix-a-flat is inexpensive, it makes the tire repair miserable. If you are willing to completely replace the tire, it may not be as big of an issue, but don't expect a "deal" from your tire repair shop if you use this product, and want to keep the tire.
In My Humble Opinion (IMHO)
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is online now   Reply With Quote
Old 11-16-2004, 12:11 PM   #4
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
On the same subject... Is it safe to use on of those tire plugging kits on a trailer tire? I have had good success with them on my vehicles, but am not sure if they are good enough for a simple "hole in the tire" repair for trailers.
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 11-16-2004, 02:47 PM   #5
Rog0525's Avatar
Images: 11
Tire repair
I've only used Fix-a-flat to get me off the highway to a safe tire changing area, then scrapped the bad tire or saved it as a spare.
Plugging a penetrated trailer tire is also risky business. I would only save a plugged tire as a spare.
Let's face it, we millionaire Airstreamers can easily shell out a hundred bucks or so to replace a defective tire. It's chickenfeed compared to the lewd amount of $ we invested in our pride and joy.
Better safe than sorry.
Rog
Old 11-16-2004, 05:16 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Exclamation
A "plug" is a temporary repair, good to get you somewhere you can get the tire permanently repaired with an internal patch. Whether the tire can be re-used depends on how good a job you dig plugging the tire, where the puncture is located, and how long the tire was run low on air before attempting to plug it.
Basically, a repairable puncture is in the tread, more then 3/4" from the outside edge of the tread. A puncture anywhere from the edge of the tread up the sidewall to the bead, is non-repairable, and the tire requires replacement.
Old 11-16-2004, 05:20 PM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i have a spare, it is located directly under the living room couch.
i agree, a patch, plug or fix a flat is only a temp. fix.
john
you call them ferrets, i call them weasels.
Old 11-24-2004, 08:46 AM   #8
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by vajeep
...2) Where do you keep your spare?
This picture shows my OEM setup.
Tom
Old 11-24-2004, 08:57 AM   #9
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
So tcwilliams, you think I can move my LP tanks forward on the hitch to create a place for the spare? And just what does that mount (hardware-wise) look like?
eljay is offline   Reply With Quote
Old 11-24-2004, 09:03 AM   #10
TomW's Avatar
1967 26' Overlander
eljay,
Here's an old thread that shows a good picture of the spare tire carrier. The tire cover came from JCWhitney's Jeep section.
Tom
Old 11-24-2004, 09:22 AM   #11
Tire plugs safe ?
In most cases tire plugs are safe for small punctures . They are not intended to be permanent. One nice thing about them is if you have a compressor with you it's possable to plug and reinflate without removing the wheel. One thing to remember plugs only work on TUBELESS tires.---Pieman
MikeL is offline   Reply With Quote
Old 11-24-2004, 11:02 AM   #12
markjoandall's Avatar
2001 30' Excella
Bedford , New Hampshire
Abe:
I have a spare tire also. Right now it is on the living room couch and it goes every where I go. My belt holds it in, Unfortunately.
-Life is a journey, not a destination.
Aerosmith
markjoandall is offline   Reply With Quote
Old 11-24-2004, 12:32 PM   #13
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
Although we have not travelled much yet - we are very cautious about our spare tire.
It lives under the trailer right behind the A-Frame - in what we think is an original set up. The carrier is bolted directly to the frame and uses a pin-hinge system to lower it to the ground - still have to craw under a bit to drag it out - but we may rig up something to fix that such as a clip on nylon-wire lead.
We need to invest in or fabricate a protective sleeve or something to prevent projectiles from the road coming up and damaging the tire. Wouldn't that be a bummer to have a flat spare! But then again that is why we pay for CAA/AAA.
Would really like to get one of those "Flat Tire" sensors - but the price will have to come down a bit. Wonder if you could make your own somehow???
Here is two pictures of the simple but out of the way and effective tire carrier we have under the Globetrotter. Looks like they just go up into the frame a bit and weld what we call an odd bike frame to hold the wheel in place. The handle/leaver comes forward into the A-Frame for easy access and came with a padlock - a must so that the hinged carrier never falls down while trailering - and also acts as a 5-finger discount deterrent.
Looks fairly easy for the handyman to rig up on the older trailers.
Name:	Tire Carrier1.jpg
ID:	9524   Click image for larger version
Name:	Tire Carrier 2.jpg
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Front spare tire mount walter1 Tires 4 10-07-2004 11:05 AM
Spare Tire DEO 2005 Safari 9 06-01-2004 03:46 PM
Spare Tire Carrier Pahaska Our Community 8 08-27-2003 09:00 AM
Spare Tire? jdleezer Tires 21 07-10-2003 07:50 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
