Old 07-01-2014, 09:58 AM   #1
1990 25' Excella
cave city , Kentucky
Spare tire?
I have a 1990 Excella - it's 25' long - its tires are 225x75R, 15s. It has 6 bolt pattern wheels. I don't have a spare. What's the easiest way to get one. Is the bolt pattern standard. Will a Ford or Chevy or Dodge wheel fit it. Thanks
unit13 is offline   Reply With Quote
Old 07-01-2014, 11:04 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
The bolt pattern is common for trailers. You can get an inexpensive wheel or mounted spare at etrailer.com. VintageTrailerSupply.com has wheels but not tires. Most Airstream trailers require load range D tires although yours may not, check the label.
You need zero offset wheels. These are widely used on trailers but not on cars or trucks, so a Ford/Chev/Dodge wheel won't work.
Old 07-01-2014, 02:10 PM   #3
1981 31' Excella II
New Market , Alabama
I went to my local trailer place and got a complete wheel and tire for $100. I would not run it 100% of the time but it is fine for a spare.
Perry
Old 07-01-2014, 02:23 PM   #4
Perry
Perry.
You got a heck of a deal.
Make sure the wheel has a rating of at least 2600 pounds.
Old 07-01-2014, 05:45 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
2,600 pounds and zero offset. Otherwise it won't clear the wheel well.
Old 07-01-2014, 07:04 PM   #6
1990 25' Excella
Thanks for the input - going on a little trip this weekend - hope I don't need a spare tire (although I'm going to get one) - probably need a spare everything - again thanks for the good help
Old 07-01-2014, 07:34 PM   #7
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
That's what I said. Well you guessed it. In the campground flat tire. Luckily I had a tire (no wheel). When I called Good Sam, I explained the tire no wheel, so the repairman was equipped to change tire spare tire to the flat tire wheel. It would have definitely been easier if I had a spare tire on a wheel and cheaper! Extra charge to brake a tire off the wheel and reinstall. Better be safe then sorry. I now have a proper spare tire on a wheel!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 07-01-2014, 07:45 PM   #8
1981 31' Excella II
I mounted in on the axle and it fits. The rim is D rated or better.
I am sure it would have been 2 or 3 times that at an RV place. This place builds trailers and I don't think they markup stuff that much.
Perry
Need a soft tire cover for front-mounted spare tire! Bessie1968 Tires 10 05-10-2013 10:05 PM
16" spare tire vs OEM spare tire rack Bluto Wheels, Hubs & Bearings 22 04-30-2013 05:13 AM
Creating a spare for the spare easyride Tires 0 06-10-2008 04:16 PM
Need a new tire/wheel for spare. tenrsingr Wheels, Hubs & Bearings 10 02-06-2005 08:58 AM
Spare tire storage mysilverbullet Our Community 9 10-23-2002 10:35 AM
