Old 03-12-2016, 03:55 PM   #15
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Originally Posted by tjdonahoe View Post
Ray Eckland, you don't want to know what I think of Maxxis, greenball and Carlisle tires ,they are all Chinese ,no more of junk here....
Maxxis tires are made in Tiawan not China.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 03-12-2016, 04:04 PM   #16
SeaLevel's Avatar
Jupiter , Florida
Originally Posted by dcasr View Post
Just be aware that the Maxxis are SPEED LIMITED to 65mph. If you are going to drive 70 and occasionally faster, keep looking. If you actually drive 60 mph with occasional 65, buy them.
I am on my second set of Maxxis. The first set aged out at 3 years, and I had driven them at 70-75 mph not knowing about the SPEED LIMITED factor, and I had two tread separations, caught before any damage was done.
My next set of four will be an upgrade to 16" Michelins LT E rating.
These have an R speed rating:
http://www.amazon.com/Maxxis-M8008-R.../dp/B004QL6I0U
SeaLevel is offline   Reply With Quote
Old 03-12-2016, 04:30 PM   #17
Mrjkq's Avatar
Venice , Florida
The Maxxis E rated tire has a speed rating of 100 mph. I drive at 65 mph max when towing, sometimes exceed that to pass so that 100 mph speed rating Is well within my limits.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Old 03-12-2016, 05:21 PM   #18
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Ray, Michelin LTX MS/2 tires, over a year now, they're great tires and do well with all the boondocking. On 16 inch wheels. No regrets. Also from Costco.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 03-13-2016, 09:05 AM   #19
Tincampers's Avatar
Sneedville , Tennessee
Originally Posted by SeaLevel View Post
Don't believe everything you read. They also say that Marathons have an R rating. Neither is correct.
Tincampers is offline   Reply With Quote
Old 03-13-2016, 09:36 AM   #20
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
And I wish that the E rated Maxxis had been the tire that I had been able to prove to be the successor to the Marathons. I kept these inflated to 80 psi and traveled around 60-65 mph all their life. Indoor storage when the trailer wasn't in use and two of the four suffered belt separation on their first trip on year 4 of use. The Marathon's started to fail at the end of year 3 of use. ST tires just don't have the ability to handle a heavy Airstream reliably for the 4-5 year lifespan that most of us expect from trailer tires.
The tall tires next to the shorter ones are the failed Maxxis tires with separated belts. Luckily I detected these before a blow out.
Jack
ID:	258677   Click image for larger version
Jack Canavera
STL Mo.
AIR #56
Old 03-14-2016, 01:23 PM   #21
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
There is a difference ?. I wouldn't run either one on the steer axle of my KW ...
Old 03-14-2016, 01:45 PM   #22
Gainesville , Florida
No body is saying that they should be run on a steer axle. They are ST tires.
Old 03-14-2016, 09:04 PM   #23
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
What I am saying is if they aren't good enough for the steer axle then I don't want them going bad on my airstream and doing damage to it, costing a lot of money...there are no bargains out there, you get what you pay for....16" michelins-$187... 15" greenball- $138..
Old 03-14-2016, 09:50 PM   #24
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Tires that are not designed to be on a steering axle are not good or bad. They have been designed to do a specific job. Using something not designed for the job you have assigned means the user has misapplied the item for the job.
Like using a screw driver to punch a hole in metal. It may do the job and yet was not designed to do that job or application.
So using tires that are designed to be used on a trailer in the manner the tires was designed (Speed, inflation and ....) should work.
Or using directional speed rated tires on a trailer that are designed to be used on a passenger car doesn't work either. Sure they are designed for a steering axle. They are not designed for a travel trailer.
There isn't good or bad. Only in application or mis-application does the tire become good or bad.
>>>>>>>>>>>Action
Rivet Popping due to Tire Stiffness? Maybe not. Ray Eklund Tires 57 07-05-2016 04:14 PM
"Service A due" message weirdstuff Sprinter and B-van Forum 17 07-12-2014 09:56 PM
Damages sidewall & Tire Change due to "Evil Rock" with pics.... JFScheck On The Road... 40 04-24-2013 08:43 AM
plumbing damage due to tire blowout TJ Rice Waste Systems, Tanks & Totes 7 10-14-2010 12:12 PM
