Old 04-17-2016, 04:27 PM   #1
2016 22' Sport
Glenville , New York
Single Axle VS Double/tripple Axle Travel Trailers & P/LT Tire De-Rating Factor ?
When using a LT tire on a single axle Airstream trailer instead of a ST tire does the de-rating of 10% or the .909 factor rule I keep reading about really need to be considered in the decision when deciding the load requirements of a tire? Every thing I have read just says a ST tire when used on a trailer. I have only read about the additional stress factors that are put on the tires when used on double/triple axles. Correct me if I am wrong, I thought the stress factors on the side walls of a tire on a single axle travel trailer were a non issue when compared to the trailers using double/triple axles.
jcole is offline   Reply With Quote
Old 04-17-2016, 05:10 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
De-rating only applies to P-rated tires (passenger tires).
Old 04-17-2016, 06:35 PM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The single axle trailers are light. LT is almost overkill. Look to see what Andrew Thomson is putting on those at his dealership.
Single Axle vs Double Axle AS Wantabe Towing, Tow Vehicles & Hitches 52 04-23-2016 06:00 AM
Excella tripple axle wheel cover (blue and white stripe fabric) hayfever 1984 -1986 Excella 1 12-12-2014 02:45 PM
Should Bed Config (Double vs. Twin) Be a Deciding Factor in a Vintage Purchase? fleurdenola Our Community 8 03-14-2013 11:01 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
