Old 07-31-2008, 10:16 AM   #1
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Simple question, maybe.
If I have the original 7 x 15 rims on my camper (which I think I do), and I need new tires, what size (or sizes) of tires will fit my camper?
www.nesa.org
Air No. 6427
Old 07-31-2008, 10:24 AM   #2
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
Abstract answer:
This may help with basic wheel / tire dimension information.
Tire Tech Information - Calculating Tire Dimensions
Simple answer:
We put Maxis 225-R-15 tires on our 77 Argosy.
martin.
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 07-31-2008, 10:25 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Review this thread and you will see why many of us are switching to 16 in. rims.
http://www.airforums.com/forums/f438...res-28293.html
While there are tires that will fit the 15 in. rims they are one made in China and 2 just plain junk.
Depending on the weight of your trailer consider D or E rated light truck tires.
If you do use truck tires PLEASE do not inflate them to the max as noted on the sidewall. Use the manufactures inflation chart based on your trailer weight. You will have to find this information yourself since no tire dealer will have any idea of what you are asking for.
2004 Excursion 4x4
Old 07-31-2008, 10:59 AM   #4
Got gandkids?
One of the reasons I asked the question was to avoid Chinese made tires and try to go with a truck tire. Like many, I have a horror story about cheap Chinese junk tires (in this case on my work truck). But I really don't want to turn this into another "Chinese tire thread".
I'll take another look at the thread you linked. I started reading it a while back and haven't kept up with it. I've also read several of the other tire threads and always seem to get lost in all the minutia of "sizes, offsets, bolt patterns" and other such things.
I guess it would be nice if we a single thread that explained each of the concepts in simple terms, without all the arguing. Seems tire discussions lead to some of the same problems as axle threads.
Thanks for the help guys.
JIm
www.nesa.org
Air No. 6427
Old 07-31-2008, 02:14 PM   #5
Lothlorian's Avatar
Loganville , Georgia
Jim:
I put 225 75 R15 Maxxis tires on my Overlander. They are a "D" trailer tire. I am very lucky because we have a tire installer in Loganville that has been here for many decades. Walton Tire is the place everybody in Loganville goes to. He did a great job for me. Maxxis has a distributer in Atlanta and they will give you a list of their dealers in your area. He quoted me $80.00 last fall and gave me that price in the spring. He told me they were going up in price.
SIU Bound
Brian
Lothlorian is offline   Reply With Quote
Old 07-31-2008, 02:26 PM   #6
And polishing threads. And tow vehicle threads. And WD hitch brand threads. And WBCCI threads...
Looks to me like 225 75R15 will work for your current wheels, regardless of the brand of tire you choose. I've heard both good and bad anecdotes regarding Marathons, Maxxis, and Carlisle, so I will refrain from commenting on those specifics.
Old 07-31-2008, 04:45 PM   #7
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Silver City , New Mexico
And as Andy (Inland RV) sez, go with D rated due to the nature of the Airstream suspension. If he says it, it's right on!
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 07-31-2008, 04:54 PM   #8
Got gandkids?
So the "ST" designation indicates a "Special Trailer" tire and "LT" stands for "Light Truck" tire? Have I got that right?
Also, is the "load range" stamped on the rim someplace? I'm assuming these are the original OEM rims from 1973 when the camper was built.
www.nesa.org
Air No. 6427
Old 07-31-2008, 06:23 PM   #9
Lothlorian's Avatar
Jim:
I told them "D" for a load range because that is what I read on this forum. The tire guy has done many trailers and he recommended "D".
Brian
Old 07-31-2008, 06:35 PM   #10
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Most st tires are rated @ 65 mph,now someone has mentioned Cooper makes st tires at around 100mph.So if you want to run speed limit go to Coopers or LT tires.Rims are center set, no back space,or offset. Rim should have max.weight stamped on it ,if you are going to replace,then go equal max. or exceed it.What ever tires you buy check manufacture date,it`s in fine print near bead,you could be buying tires that have sat in a warehouse for years.Tires start aging as soon as they are made,hope this helps.dave
easyride is offline   Reply With Quote
Info on Washing with Simple Green Mrs_RedSHED Cleaning, Stripping & Polishing 14 05-21-2008 10:38 PM
It's not such a Simple life. SaabLover Our Community 17 09-29-2007 01:03 PM
Simple Generator Needs Advice Sought scooterpie Generators & Solar Power 25 08-12-2007 02:18 AM
I hope it's simple! pittsf Refrigerators 4 06-19-2007 03:37 PM
Simple cleaning agent 77 R GO C MH General Interior Topics 21 06-04-2005 10:03 PM
