Old 03-31-2014, 10:26 AM   #1
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Side effect of wheel/tire change
An unforeseen effect of my 16"wheel and tire changeout has been the loss of use of my wheel stop chock. I lost one inch of clearance between the tandem axle and my chock (even though it's adjustable) cannot fit between the tires. I'm sure there are others of you who may have run into this. Unfortunately my trailer is stored and I don't know the new distance between the tires so that I can order a replacement. Do any of you know what that distance is on a 31' Classic with 16" Michelin's and/or have a model of stop chock that will fit the diminished distance?
Here is a picture of my old stop chock and a second picture of the new wheels and tires. FYI that strange box on top of the wheel chock is my outdoor temperature sensor. I used to lay it there once we were set up.
ID:	208667   Click image for larger version
Jack Canavera
STL Mo.
AIR #56
Old 03-31-2014, 10:44 AM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I recently switched to the 16" wheels and the "between the wheels" scissors type chocks that I bought from Hensley when I got my hitch still fit fine.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 03-31-2014, 10:51 AM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I'll try to measure mine tonight if you don't get an answer sooner.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-31-2014, 01:07 PM   #4
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Amazon.com: BAL 28005 Deluxe Tire Chock: Automotive
These are what I have and they work great with the 16" wheels and Michelin tires.
10Smiles is offline   Reply With Quote
Old 03-31-2014, 01:59 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We use Bal X-Chocks on our 16" Michelins, fit, work great, and stabilize the trailer. We also have the Fastway Onestep chocks for fast chocking or extra measure on grades.
Doug and Cheryl
Old 03-31-2014, 02:33 PM   #6
Missouri Valley , Iowa
Jack, we are in KC visiting our daughter as we return from wintering in FL. The measurement on my '02 30' Classic w / slide is 3.25"between the tires. I have the 16" wheels & Michelins like you mentioned. My chocks have the 1/2" threaded adjuster with the locking cam type over center latch. I had to run the adjuster out near its max but it works.
Dan
Farmer Dan is offline   Reply With Quote
Old 03-31-2014, 03:54 PM   #7
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Had the same problem with mine. They can easily be modified to fit the 16" using a coupling nut and a 2" 100% thread bolt. Think the size is 5/16 but might be 3/8.
Al - K4GLU is offline   Reply With Quote
Old 03-31-2014, 05:26 PM   #8
GCinSC2's Avatar
Jack,
I get roughly 3 5/8" on my rig. Was able to put a 4X4 (3 1/2") block of wood in the gap, slight wiggle room.
Gary
S/OS #001
Old 04-01-2014, 10:06 AM   #9
jcanavera's Avatar
Fenton , Missouri
Images: 143
Thanks all for the measurements. I'll also look at your suggestions!
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-01-2014, 12:40 PM   #10
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
My chocks look just like yours and they fit fine on my Classic 28 with 16" wheels and Michelins. I always have to rap them smartly on the ground to get them closed tight enough to fit between the tires.
John W. Irwin
WBCCI #9632
Old 04-01-2014, 02:38 PM   #11
jcanavera's Avatar
Fenton , Missouri
Images: 143
I know what you are saying, and I thought the same thing. I'm going to check the one more time just to be sure. I've got the nut backed off as far as it will go....but I bought mine about 15 years ago and they might not be quite the same as what I see on the Internet today.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-18-2014, 10:23 AM   #12
jcanavera's Avatar
Fenton , Missouri
Images: 143
Ends up the adjusting nut was frozen after years of not moving. I got them loose and found that I can collapse the chock down to fit between the wheels. Glad to not have to buy new ones!
Jack
Jack Canavera
STL Mo.
AIR #56
Polishing : too much heat on alu - effect? dufferin Cleaning, Stripping & Polishing 18 07-04-2007 04:09 AM
Frame Coating Options and effect on what type of Primer HamiBambi Repairing/Replacing Floor &/or Frame 21 04-30-2007 08:33 AM
The effect of using the blue liquid black water treatment on septic fields wacnstac Waste Systems, Tanks & Totes 6 06-01-2006 09:21 PM
solar effect? norbert Our Community 2 06-21-2005 09:22 AM
