Old 07-01-2015, 09:25 AM   #15
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by A W Warn View Post
An exception to this advice: I cannot inflate my tires to the maximum allowed pressure on the sidewall since it would exceed the maximum allowed inflation pressure of my wheels. My E rated tires' sidewall says 80 PSI max. My wheels say 65 PSI max.
You need different wheels.
Old 07-01-2015, 09:27 AM   #16
Gainesville , Florida
Thank you!! I have mentioned that in the past and have been ignored. Good info.
Old 07-01-2015, 09:33 AM   #17
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Sharp Turns: Blowout Cause?
One thing I have always wondered about is high altitude driving. I remember my first trip to Colorado and the bag of Potato chips that we brought from St. Louis. At we climbed in altitude from Limon Colorado to Denver, we watched that bag of chips swell up. I realized that as we climbed, the air pressure was lowering. The pressure inside the bag of chips remained the same as their fill location, thus with less pressure pushing against the bag, it swelled up.
So taking this thought to tires, the question comes to the same sceneiro. If I were to check the tire pressure would the internal pressure be higher reflecting the lower atmospheric pressure due to altitude? Sort of the same question in reverse, checking tires at cool temps and higher altitudes, when I hit the hot afternoon in Kansas should I be checking tire pressures after coming down to lower altitudes?
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-01-2015, 09:45 AM   #18
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Your statement is an opinion, not a fact.
The E rated tires' capacity is overkill for my Safari.
Wheels have held up fine in the 16 years they have been rolling.
I'm happy with what I have. YMMV
Alan
Old 07-01-2015, 10:56 AM   #19
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Trailer tires are to sidewall max in TT applications. And wheel rating needs to match or preferably slightly exceed tire rating. Tires and wheels need to be a match.
You might want to review what constitutes "fact". Your mismatch is bad practice, but it's your trailer.
Old 07-01-2015, 11:20 AM   #20
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
To original poster - If I were you I would replace the tires now, with 12,000 miles on them and an off brand. To me just not worth the possibility of the tires losing it and having an accident.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 07-01-2015, 11:21 AM   #21
jcanavera's Avatar
Fenton , Missouri
Images: 143
In most cases running an E rated tire lower pressures reduces the load capacity. I ran E's on my Classic and if I had run them at 65 psi, the load capacity would have been the same as my Marathons that were D rated. AW Warn, I'm just curious why you went to E's? I don't know in all of the tire talk whether the extra ply strength of an E translates to a benefit at lower pressures. I know I went to E's to be able to run higher pressure which gave the tire more load reserve.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-01-2015, 12:45 PM   #22
1967 26' Overlander
Spartanburg , South Carolina
It is a good idea to stick with ST tires which are designed to withstand side wise stresses such as found in tight turns. Last I heard Michelin does not make ST's. I run Good Year Marathons and have had good service in spite of the fact that to back into my driveway from a narrow street I have to angle the trailer almost to the point of jack knife, So far my tires have not been a problem doing this.
Jacob D is offline   Reply With Quote
Old 07-01-2015, 07:53 PM   #23
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Jack
The load capacity of a D and E at the same pressure, in the 60 PSI range, are basically identical. Since the E rated tire allows higher inflation pressure, its maximum load capacity is increased above a D.
There is more than one reason I went with the tires that I did.
(1) When I went to the Airstream factory I asked what they recommended for my trailer. What they offered me that day were a GYM D or a Power King Tow Max D or E.
(2) The dealer I use near my home recommended the Power King Tow Max E over the other tires he sells.
(3) I liked the stiffer sidewall.
(4) The cost difference between D rated and E rated tires was very little.
(5) The E rated tire at 60 PSI far exceeds the load requirement needed for my trailer
I've towed my Safari about 10,000 miles on these tires in ~4 1/2 years. There is very little evidence of wear. I would replace them with the exact same tire without worry. Though, I am considering Michelins next time. I will be replacing the tires next spring, due to age.
Alan
Old 07-01-2015, 08:21 PM   #24
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Alan, Thanks for the explanation and your rationale.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 07-02-2015, 07:27 AM   #25
Airborne6's Avatar
2015 23' International
Lakeview , Arkansas
Curious. With the tpms do you adjust psi throughout the day or just leave it from the AM check. Traveling from Moab to Panguitch I saw a 10 psi gain once on the road. Dave
Some days your the bug.
Some days your the windshield.
WBCCI # 1959
Black 2015 Toyota Tundra TRD Pro CrewMax
2015 23D International Signature (Salsa)
Stella our Bull Pointer mix
Airborne6 is offline   Reply With Quote
Old 07-02-2015, 09:56 AM   #26
dznf0g's Avatar
Oswego , Illinois
Leave the pressure at "cold" morning recommended pressure. Don't adjust throughout the travel day. What tires and pressure are you running. 10 PSI is quite a bit, unless your are running 80 psi cold.
-Rich-
Old 07-02-2015, 12:00 PM   #27
Ravenna , Ohio
You are correct re wheel max.
In your case LR-D might have been a better investment as LR-E gives you almost nothing since it is the inflation that carries the load and that affects the Interply Shear.
Tireman9 is offline   Reply With Quote
Old 07-02-2015, 12:04 PM   #28
Ravenna , Ohio
Jack
Sorry to sound like a broken record but I have 3 Blog posts that mention Altitude (Elevation) and one has the math for those so inclined to demand the "proof". You might want to link to the blog and use the "label" system or the search box (upper left) to see if the answer has already been covered.
Key Turns and Turns..is this normal? help shiny1973 Doors & Locks 10 11-25-2008 04:57 AM
Is this Airstream a Lost Cause JohnG Off Topic Forum 6 07-13-2004 10:06 AM
