Old 05-28-2014, 07:27 AM   #1
travelfables
travelfables's Avatar
1964 22' Safari
Somewhere Beautiful , Florida
Seeking Tire Advice for Single Axle (1964 Airstream 4000lbs)
I'd love some tips from Vintage Owners regarding tires.
Which ones to order, which wheel size etc.
Things to note:
  • My rig is a 1964 Safari SINGLE AXLE. (it had some old tires on it that were hell to take off, so tire width is a real issue.
  • I'm going to have to purchase both wheels and tires
  • The weight of my rig (according to the vintage documents found in it) is 4000lbs.
(other notes, As a long time RVer in Some Other Brand , I will not run anything with Carlise or Firestone in the name, and I realize that there are tons of tire threads here and trees in the forest.)
Help, hints , advice and current info from Vintage Single Axle Airstreamers greatly appreciated.
travelfables (The Can Can 64 Safari)
RivetPunk.com
travelfables is offline   Reply With Quote
Old 05-28-2014, 01:17 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
If you had trouble getting the tires off, chances are that you need a new axle, also.
If possible weigh your rig before buying tires.
If you want something that looks stock, I'd suggest this wheel and the accompanying hubcap:
15" Trailer Wheel
Reports on fitment vary from one trailer to the next. You may be able to fit 225/75R15 trailer tires, which would give you the most capacity. If they would rub you may have to use 215/75R15 or 195/70R15 light truck tires.
There are limited selections of brands in these sizes. I have Goodyear Marathons, which have worked out for me, but lots of people hate them.
Old 05-28-2014, 03:14 PM   #3
travelfables
1964 22' Safari
Cool Jammer! Thanks for the Tip. I think my removal issues were due to the random junk that was on the rig, and the place it was in. Axle has a bit of life left in it. Has anyone put a 16" tire (and wheel) on one of these? Yes, a slender one? I think the (front to back) clearance is fine if I cut away a silly lip on the bottom of the trailer hub that serves 0 purpose? I don't care about the Vintage thing, just function, and quality. I've run Marathons on other non-Airstream rigs in the past, and was happy as well.
RivetPunk.com
Old 05-28-2014, 04:57 PM   #4
r carl's Avatar
Lin , Ne
These would be great for your camper.
http://www.tirerack.com/tires/tires....rtnum=700R5215
Old 05-28-2014, 05:06 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
While that link doesn't specify P or LT, the description speaks of use in passenger cars and light trucks. If that makes it a "P" rated tire, you would have to derate that 2040 lb capacity by 10% if used on a trailer - bringing its load carrying capacity to 1836 lb per tire.
Old 05-28-2014, 05:40 PM   #6
r carl's Avatar
Lin , Ne
Its a LRD LT tire. All the info is on that link. I have them on my 30' Avion. They are heavy duty I assure you!
Need advice .. single vs double axle faller73 Towing, Tow Vehicles & Hitches 4 09-23-2012 11:49 PM
Seeking axle rating advice Mr Jolly Axles 14 11-27-2011 06:20 AM
Axle on 1955 single axle models? glacierrunne Axles 7 02-12-2010 02:38 PM
1964 Airstream Tradewind 24' single axle classic look eBay Watch Airstreams on eBay 0 05-24-2009 06:00 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
