Old 06-10-2014, 03:36 PM   #29
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Second Blow Out, Gremlins? Chinese Tires?
Are the random odds really one in sixteen..... Or are the odds actually one in four?
Think about it....
The odds were one in four the first time when "the point was set", and then one in four when you made the point. The odds of the same tire blowing is only one in four.
Any way you cut it, each time the die is rolled it is a new beginning, the history matters not.
Old 06-10-2014, 03:40 PM   #30
2014 16' Sport
Route 66 , Arizona
A fair coin is always 50/50, each and every flip. Even if it landed tails 9 out of 10 times. That tenth flip is still 50/50.
Skooter is offline   Reply With Quote
Old 06-10-2014, 07:33 PM   #31
K.C. , Missouri
According to the 50/50 rule, when I grab a plug to stick into the 120v outlet, I should have picked it up half the time oriented correctly to go in the darned outlet. How I seem to NEVER get it right the first time ?
gmw photos is offline   Reply With Quote
Old 06-10-2014, 08:06 PM   #32
r carl's Avatar
Lin , Ne
When I go to plug in a two prong plug, at least 9 out of 10 times its backwards.
Old 06-10-2014, 10:21 PM   #33
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
True dat Carl.
Old 06-11-2014, 03:12 AM   #34
Beneath the title
jnerges's Avatar
2005 28' International CCD
Mount Pleasant , South Carolina
Since we are talking statistics, 100% of the time, I don't listen to wife and it works out anyway. Explain that one?
Called the place where I bought the tires yesterday. The guy said: "Goodyear has left a really bad taste in my mouth, I don't like the company, there is no warranty but if you bring the tire in, I will send it back to the company, they will take a month to decide and send a note back saying it was a defect".
Fortunately, I have another tire in the meantime and no big trips planned, I will keep you posted.
Thanks again all, great discussion.
Aunt Gladys, 28FT, Intl'
"Man, it's hot here, is the heat on?"
jnerges is offline   Reply With Quote
Old 06-11-2014, 10:32 AM   #35
richw46's Avatar
Lexington , Kentucky
Murphy's law, stated mathematically:
Given a 50:50 chance that anything can go wrong, 9 times out of 10 it will.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 06-11-2014, 11:29 AM   #36
kokopat's Avatar
Hendersonville, NC , North Carolina
In 2009 I got bit by the I-26 gremlin. I was towing a 2002 Hi-Lo home from Camping World and the road felt really smooth so I bumped her up to 70 when the back end did a little dance. I pulled over to find the right rear tire had separated. All my bad - too fast, an old set of tires and the being on the gremlin highway.
kokopat is offline   Reply With Quote
Old 06-18-2014, 07:21 PM   #37
Beneath the title
jnerges's Avatar
Possible Cause
Camping World in Charleston called me today, diagnosis is......
There was a broken wire from the brake controller to the left front wheel. Whenever I hit the brakes, the two left wheels braked normally, the right rear applied its brake but the right front did not.
The right wheel was braking and the left wheel was not. The technician suggested this heated the right rear tire up and shortened its life.
Sounds reasonable. Any thoughts?
Either way, they will check alignment, rotate tires and fix the broken brake wire.
I am still waiting to hear from Goodyear on whether they will replace the tire.
That's all for today update, except the AC had a big mud dauber nest that made it rattle, the cleared that up too. The South is a tough place to survive some times.
Old 06-18-2014, 08:47 PM   #38
HowieE's Avatar
Princeton , New Jersey
Images: 12
The broken wire would have NO effect on the remaining tires, either side. Electric brakes are applied as a function of amperage applied by the brake controller. The lose of one brake would not effect the others. The most reaction one might expect would be a pulling of the trailer to the side with more functioning brake.
Join the group. Goodyear tires just fail. That is what they are know for and they are good at it.
2004 Excursion 4x4
Old 06-18-2014, 09:01 PM   #39
K.C. , Missouri
I'm glad you titled that "possible cause". Key word there is "possible". But "not likely".
I'm with Howie on this one.
Replace them with good tires and leave those worries behind.
Old 06-18-2014, 09:14 PM   #40
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
A brake drum has to get very hot to pop a tire.
I really really doubt this is the cause, and I doubt the problem as described would induce much if any additional heat.
Old 06-19-2014, 05:05 AM   #41
CapriRacer
CapriRacer's Avatar
I'm in the , US
I don't know why I haven't been following this thread, but I apologize - and have, I think, something important to add.
First, thanks jnerges, for the photos.
What I see is a Run Flat condition - that is, the tire lost inflation pressure in some way, and usually that's because of a puncture. So the first step to confirm is to look for a puncture in the tread. Whoever looks should look on the inside. It's easier to see by looking on the relatively smooth inside rather than the highly textured outside. 90% of the time I can find the puncture I am looking for. The other 10% it's likely the puncture is in the damaged area.
While there is a separation, it doesn't follow the right sequence for a separation caused failure. I think the separation is an artifact of the run flat condition and not the cause of the the run flat condition.
So, no, I don't think this is caused by a defect, nor do I think there is any connection between the tire failure and the brake issue. Just large coincidences.
CapriRacer is offline   Reply With Quote
Old 06-19-2014, 05:28 AM   #42
Beneath the title
jnerges's Avatar
I had a feeling the brake wire problem was a stretch. I am happy they found it though, It was very subtle but I had to increase the setting on the brake controller lately. We will see if this fixes it.
I pick the trailer up tomorrow. Right now the fractured tire is at Goodyear for "X Ray Inspection". Who knows, Maybe I will get a new one, if we go across country again, I will probably trade them all out, I don't know. We had 90% good luck with Marathons and 10% bad, give or take 90%.
Tire blow out- anyone using Carlisle tires? NJtoNC Towing, Tow Vehicles & Hitches 63 09-06-2012 12:48 AM
Chinese 'Hi-Run' Tires Quality ? gowansgary Tires 5 04-22-2010 02:39 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 10:11 AM
Airstream Gremlins! Cracker General Repair Forum 13 04-03-2008 10:47 AM
gremlins// fuel system wb13798 Mechanics Corner - Engines, Transmission & More... 5 10-28-2003 08:53 AM
