Old 10-19-2012, 04:44 PM   #127
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
What is Michelin supposed to say? I am sure that they have not tested Lt tires on Airstream travel trailers.It does not mean they wont perform well.
I think if you spend some time reading the forum it is fairly easy to figure out how well the Lt tires perform on our trailers.We have tested them on our trailers.
Then compare how well the ST tires have performed we have tested them also.Draw your own conclusions.
You might as well have asked them if they would warranty the tires if used for a tire swing.
The answer would have been the same........My 2 cents
Old 10-19-2012, 08:42 PM   #128
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Re: all of the above questions and comments (and any after this), I have no answers, nor strong opinion either way. I was just sharing the information.
Alan
Old 10-20-2012, 04:28 AM   #129
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Part of the "answer" to these questions, for me, was:
Craftsman Horizontal 3-gl Air Compressor
as ten tires to keep up with warranted something decent. A little heavy, and a little big (except when ones "traveling garage" is the back of the pickup truck). This dude is fast. (And will have other uses on a project trailer). About a foot and half high.
Now just need an equal quality air gauge.
Good questions above.
I'm sticking with "simple" (max on TT, and staying inside TV mnfrs numbers with a bit of experimentation up or down), and, as I don't intend to travel at high speeds (65+) solo or towing, hope that no more than morning temps & altitude will affect readings. As daily tire pressure readings -- prior to any travel -- is a basic (along with re-torquing wheel stud nuts), the 10% pressure rise maximum seems seems simple.
Individual weight scale readings on all wheel positions to work from (TV done, TT yet to come once on scale with WDH applied) as the beginning.
Gonna have to go read that TPMS thread now.
slowmover is online now   Reply With Quote
Old 10-20-2012, 07:56 PM   #130
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by dznf0g View Post
Well, I found something. Have no idea as to the credibility of this read. Capriracer....care to share your knowledge as to these temps and how we may interpret them using infrared on the outside of the tire shoulder and using TPMS (both the pressure rise method and stem air temp method)?
Why Temperature?
(is there an error in #2 sub section 3? Shouldn't those be Farenheit figures, not Celsius?)
80C = 176F
I guess I'm dull after some long days behind the wheel. What is it you're trying to find (or be able to predict)?
Old 10-20-2012, 08:10 PM   #131
dznf0g's Avatar
Oswego , Illinois
Originally Posted by REDNAX View Post
80C = 176F
I am trying to understand why I have 7 -9 psi rise on the AS Michelins at 65 and 70psi cold with a little less than 2000 lbs load on each tire. It makes no sense to me compared to P and LT tires on the TVs and cars I have driven and does not correlate to what I would expect per the load/pressure charts. 7 - 9 psi is too much of a rise and indicates a 70 - 90* rise in temp.......but how to verify that?
What does 70 - 90* rise in internal air temp mean relative to the actual rise in temp in the shoulder area....and how do we measure that without a partially destructive probe Pyrometer? That is ALL the discussion above in a nutshell and abbreviated.
-Rich-
Old 10-20-2012, 08:35 PM   #132
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Thanks. I gits it now. Prediction
To cover the bases (and for those wishing to replicate method):
1] Are these pressures taken after at least 1.5-hrs steady state driving? Versus cold pressures taken that morning prior to departure? Easy braking to the full stop? (Preferably readings from a number of stops).
2] The load on the individual tires is taken from scale data with WDH applied?
3] The axle alignment is verified dead-on perfect? No brake drag? Bearing pre-load is correct? Axle rubber pliable/functional? The hitch is not canting the trailer to one side or another (entirely possible depending on type/brand)?
I've written that I am in favor of max sidewall pressure on TT's from what I have learned the past few years. On the TV I would prefer to have the "lowest" correct pressure, so the point where the pressure rise is no more than 10% sort of sets itself (respective of vehicle manufacturer range of pressures, FF & RR; load reserve, etc).
If we had your TV under tow, some of the same "problems" might arise that come up with a trailer. Especially if we were yanking it around with a ten foot bar and it didn't perfectly track the vehicle towing it. And it won't.
The trailer is always moving around. Side-to-side. Have someone follow you with a video camera. Unless that trailer is hitched with a PULLRITE or a VPP style, it will be moving around more than necessary. Minimizing this motion changes stress on the tires. Winds cause the trailer to tilt as well, so the motions are from different directions (say, traffic and local winds). An aero trailer has winds pulling at it with no other type effects (versus a box type where winds push; this is relative), and all this must be set against the "pole" yanking it down the road.
Then add in road problems (grade, surface, etc).
Cumulative effects.
Think this leads in the right direction?
Old 10-20-2012, 08:39 PM   #133
dznf0g's Avatar
Oswego , Illinois
Red, Affirmative to all questions. I think you've read enough of my stuff to know how anal I am. See my reply to your post on the TPMS thread. Not sure I have a problem. Not sure which temp vs. pressure calculations to believe.
-Rich-
Old 10-20-2012, 08:51 PM   #134
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Read that and replied. I don't think it a matter of what correction seems best outside of repeatable results. If I have an upper limit monitored (temps) and the pressure rise during the day is predictable, haven't I then covered this pair of bases (for that day and on that drive)?
I don't see a problem when we posit that TT tires undergo different stresses than the TV it is following.
Reading both Barry's Tire Tech and Rogers RV Safety blog covers quite a bit on one hand, but one also comes away with what isn't said due to constraints of time, energy and engineering contexts. The threads on this forum -- and on the other RV forums (and others besides) to which they have contributed -- have added a great deal to what we may consider "safe travel", IMO.
Still, the search for "best" goes on, ha!
Old 10-28-2012, 05:44 PM   #135
dznf0g's Avatar
Oswego , Illinois
OK, so the last weekend of the season has ended..
Relative to the above posts:
I ran the LTXs at 80 psi, and saw only a 5 - 7 psi rise....well within the 10% of starting pressure. I am thinking this is the only accurate way to definitively decide on pressures in a non-conventional tire application.
I noted no evidence (at least on this short 150 mile hop) of a decreased ride quality. Towels still on the rack, etc.
I may try 75psi next spring and see if that is the 10% sweet spot.
-Rich-
Old 10-28-2012, 06:54 PM   #136
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Ok I just got back from Zion NP last weekend. 450 miles one way, 900 total. I ran my Michelins at 65 psi and had up to 6psi rise over all. Tires never ran warming than the TV by touch. Around 90 degrees. No problems and a smithy ride. My trailer weighs about 7000 lbs loaded. I'll be running 65 psi, don't see a need to run any higher.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-28-2012, 07:23 PM   #137
dznf0g's Avatar
Oswego , Illinois
I weigh in at about 9000# loaded. There's the diff. By the temp rise method (if it has merit) 6psi at 65 psi should be good. I was getting up t0 9psi rise at 65 PSI.
-Rich-
Old 10-28-2012, 08:02 PM   #138
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I'm not sure what this means. I am guessing it means a ride like a blacksmith's hammer hitting an avil.
Ken
Old 10-28-2012, 08:22 PM   #139
dznf0g's Avatar
Oswego , Illinois
Ken
Ah, but SMITHYS use to build soft springies for the ladies' buggies as well. They had a more feminine side to their hammer and anvil!!!!
-Rich-
Old 10-28-2012, 09:00 PM   #140
dznf0g's Avatar
Oswego , Illinois
But for the TT, again, it is about the stresses on the tire which are not those experienced by the TV, and they aren't going to show in psi rise. It's the turns (nearly all of them), all of the backing to & fro, etc. U-turns on fresh concrete the worst. Pressure versus load doesn't matter for TT tires. The damage is internal and cumulative.
Purman, it's the norm for the TV tires to run hotter than the TT tires (if you're using an IR gun to check tread temps at a gently made stop coming off the highway).
I am not convinced I buy this. I have pondered and waffled on it a lot. A heavily loaded truck, with LT tires traveling at 65 MPH, and a pretty harsh turn on a 2 laner....I just am not so sure the stresses are that much greater than a low speed scrub on a trailer. At speed, the scrub on a trailer isn't that great, IMO.
I think it is over estimated by most.
-Rich-
Safe Tire Pressure Morgan guy Tires 165 01-10-2013 12:49 PM
02/12: New Tire Discussion on Woodalls: LT versus ST and more. slowmover Tires 128 04-10-2012 05:09 PM
Putting a safe in 2012 27' FB Int Jordanparson General Interior Topics 5 02-24-2012 10:33 PM
Bolt pattern & tire size for 68' Ambassador silverwoman Wheels, Hubs & Bearings 3 02-16-2012 09:36 PM
