Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 01-19-2005, 05:16 PM   #1
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
RV Tire information
Found this information, and we are passing it on.
Here are guidelines to help you obtain the best performance from the tires used on your recreational vehicle (RV). Unless otherwise specified, the term "RV" applies to motor homes, travel trailers, 5th-wheel travel trailers and slide-in campers for pickup trucks. More information about your specific vehicle and its tires is contained in the owner's manual supplied by the vehicle manufacturer. Additional information concerning your tires is available from your local tire dealer or the tire manufacturer.
Tires used on RVs are subjected to a greater variety of conditions than automobile applications. Many RVs are out of service for long periods of time. When RVs are being driven, they are used at or near maximum loads during hot weather.
Normal, natural aging of a tire, as well as ozone in the air, may cause the rubber to crack, especially in the sidewall area. Tires should be checked for this condition or other damage before every long trip. Tires over five years old or ones that show signs of cracking should be inspected regularly by a tire professional to determine if they should remain in service or be discarded.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 01-20-2005, 08:16 AM   #2
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Interesting post Andy. One thing not considered is the spare tire. Most never touch the ground, and in the case of my Classic are out of the sunlight. They still get exposed to the elements and probably should also be considered suspect once they hit the 5 year mark.
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Tire opinion Dbraw Tires 12 11-25-2002 07:39 AM
Flat tire detector Pahaska Tires 6 08-08-2002 06:38 PM
Tire code info FrankR Tires 1 05-20-2002 09:18 AM
