Old 10-22-2016, 07:17 PM   #1
Cracker's Avatar
Pittsfield , Maine
Running a 34' on Two axles
I tried a search but without luck. I've been told that you can run a 34' on two axles for a reasonable distance. In other words, do you need a spare on a 34'?
Cracker
Cracker is offline   Reply With Quote
Old 10-22-2016, 09:01 PM   #2
Vintage Kin
Fort Worth , Texas
Probably not on any of these trailers given choice of best tires and scheduled replacement (3-5 years).
1990 35' Silver Streak
2004 555 Cummins
Old 10-22-2016, 09:12 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You can run three tires on a torsion bar tandem axle as well, slower speed and reasonable distance, our Owners Manual describes it. The spare was optional on previous Airstreams. Carrying no spare saves a little hitch weight and is more viable with the highly reliable tires available today.
But we are not the adventurous lot of earlier Americans who liked to travel light, simple, and enjoyed roughing it.
Doug and Cheryl
Old 10-22-2016, 09:16 PM   #4
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
You can limp down the road with only one tire on a tandem axel airstream and loosing one tire on a triple axel not a problem. Remove the wheel and go slow.
Al Boondy is offline   Reply With Quote
Old 10-23-2016, 12:08 PM   #5
San Antonio , Texas
On AVION's you can "chain up" the axle and go reasonably slowly to the next place you can get it fixed
Ralph12 is offline   Reply With Quote
Old 10-23-2016, 12:21 PM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
It will depend on what tires you are using and what pressure they are inflated to.
I run 16 in. E rated tires. The scheduled inflation for my weight is under 40lbs. I run them at 45 lbs, a pressure that will carry the trailer on 4 tires or 5 is one is flat. If I have a flat I will remove the flat and place one of the center axle tire in it's place. Balancing the trailer on the front and rear axle
2004 Excursion 4x4
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 01:01 PM
Two 12V vs. two six volt batteries spat61 Land Yacht/Legacy Motorhomes 37 04-23-2010 12:50 AM
Two plus two cello The Pet Forum 1 09-26-2006 03:00 PM
Two 6 volts or Two 12V series 27 LI Pets Electrical - Systems, Generators, Batteries & Solar 0 09-07-2006 07:06 PM
