Old 02-14-2006, 09:18 AM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Question Rotate tires?
I'm embarassed to ask, but I would rather be embarassed than tear something up: Am I supposed to rotate the tires on my coach? If yes, how often? And is there a recomended pattern?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-14-2006, 11:06 AM   #2
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Rodney,
When I repack my wheel bearing and adjust the brakes, I rotate the tires as well. I keep them on the same side and just move them from the front axle to the back axle.
Dwight is offline   Reply With Quote
Old 02-16-2006, 05:51 PM   #3
1992 34' Limited
Falls Church , Virginia
OK, I'll go you one (axle) better....!
Hi all -
Is there a recommended tire rotation pattern for the triple axles?? SilverToy only has about 1000mi on the new tires but it never hurts to be prepared....
Do I stay with the tires on one side but bump them backward/ forward one axle? Swap sides and locations...? I'm all ears!
Thanks!
Axel
SilverToy is offline   Reply With Quote
Old 02-16-2006, 06:37 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Actually I wonder if rotating tires is a good idea on an Airstream or not If you balance the entire running gear assembly...you would have to re-do it everytime you rotated tires Unless you were using something like Centramatics FWIW I don't bother to rotate my trailer tires, they usually rot out before the wear out. And I don't rotate the tires on my truck either...to much of a pain I usually get even wear on the rear end and it is no fun to rotate duals
Aaron
WBCCI #XXXX AIR #2495
Old 02-16-2006, 08:03 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
For a triple axle, it would be:
Front to back
Back to middle
Middle to front.
There is a pattern for cross-rotation, but I have had too much trouble with belt separation to reccomend it. Here it is anyway, if you are daring:
Front to back
Back to opposite side front.
Triple axle is similar, just add another pair of tires.
Front to middle
Middle to back
Old 02-16-2006, 08:12 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
If you're worried at all about tire balance, try a product called Ride-On. It is a water based tire sealant that balances the tires as you ride. Takes a few miles each morning to get the stuff evenly distributed around the contact patch, but is great after that. I use it in all of my rolling stock and have yet to get e flat.....anywhere in 5 years! www.ride-on.com
Old 02-16-2006, 08:59 PM   #7
Well Preserved
1993 21' Sovereign
There is also the sand-balance method, kind of the poor man's centramatic.A small sandbag is inserted in the tire, then the tire is inflated and installed on the vehicle. The sand moves to the light spot in the tire, smoothing the ride. I have used it in big-truck tires, as well as some 19.5" tires, similar to the ones on most Airstream motor homes. Results from this have been mixed.
If the front end is in good condition, it works pretty much as advertised. However, if you have any wear at all in the ball joints, tie rod ends, etc, it will make the problem much more noticeable.
Old 02-16-2006, 09:33 PM   #8
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Aww crap
And to think I drank to much before I bought thish thing.... balance smalacnce for the love of gawd
Rodney
and the
My Blog
Old 02-17-2006, 05:15 AM   #9
Well Preserved
1993 21' Sovereign
Remember, you are not an alcoholic. Alcoholics attend meetings. We attend rallies....
Old 02-17-2006, 05:48 AM   #10
lewster's Avatar
More like an 'alumaholic'
Old 02-17-2006, 09:15 PM   #11
Well Preserved
1993 21' Sovereign
Hi. My name is Terry, and I'm an Alumaholic...
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
Goodyear G670 RV Tires??? TRAPEZE Airstream Motorhome Forums 16 11-27-2006 03:19 PM
Whitewall Tires 66whitebread Tires 0 09-17-2002 06:29 PM
Goodyear G670 RV Tires??? TRAPEZE Tires 2 07-08-2002 05:38 PM
Best wheels & Tires... Andy R Wheels, Hubs & Bearings 4 04-15-2002 10:41 AM
