Old 03-22-2009, 04:36 PM   #1
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Question Rim Size
I have the chance to pick up some nice alloy rims, my concern is are the 15" or 16" rims. They have no markings on them and I am not 100% sure as to where to measure them to get the true size. Any one have any help?
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 03-22-2009, 05:00 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
A 15 in. rim will measure 16 1/4 in. dia. and a 16 in. whel will measure 17 1/4 in. dia.
Be careful the offset measurement is another consideration when selecting a rim. The 16 in. rims I am using have a 8mm offset. These is what determines the clearance from the tire to the vertical sidewall of the wheel well and the fender edge.
I can't tell you how to measure offset but any tire shop that sells rims will be able to.
2004 Excursion 4x4
Old 03-22-2009, 05:49 PM   #3
Tarheel's Avatar
Images: 21
Thanks I will do that tomorrow when I go to look at it. They will be going on a Jeep Wrangler so there is pleanty of clearance.
WBCCI # 348
Old 03-22-2009, 06:25 PM   #4
Graham , North Carolina
I think you also need to be concerned with the lug pattern. Make sure they will fit your pattern
Jerry
jerrypeterma is offline   Reply With Quote
Old 03-22-2009, 08:11 PM   #5
1972 Travelux Princess 25
Cobourg , Ontario
Wheel measurements are actually tire measurements, measured to the inside of the tire bead. In other words a 15" tire will measure 15" across the hole.
Measure your wheel inside where the bead seats, or measure as Howie E says.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
rim size meausre
Is this a split rim???? Benjo Wheels, Hubs & Bearings 21 04-18-2009 04:56 AM
What does a split rim look like? tbrom Wheels, Hubs & Bearings 9 09-30-2006 04:58 PM
63 flyingcloud tire n rim size 63streamer Tires 1 06-19-2006 10:56 PM
Motorhome rim size question RichardT Airstream Motorhome Forums 3 11-20-2003 10:41 AM
Split Rim Or Not? Jabba Wheels, Hubs & Bearings 3 11-11-2002 07:43 AM
