Old 09-08-2014, 07:24 PM   #1
SilverEagle6's Avatar
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up , Traveling the USA
Right front tire wearing
My right front tire is wearing out on the outside and the wear has been dramatic. I pay close attention to my tires and last night during set up the tires looked fine. We were camped at a BLM campground in Montana and had to drive out on a gravel road door about 15 miles....some of the road had some pretty bad wash boarding. 168 miles later after checking the tires I noticed the outside tread was almost worn down to "smooth" . Pressure in all for tires are good, weight in the trailer for this trip ( 13,000 + miles) has been the same and cargo evenly distributed.
Any idea on cause, could it be a broken belt from the wash boarding?
Thanks, john
Jeanne and John, and always with us...Jake
2008 30' Classic Ltd Rear twin, 2014 Ford Super Duty
WBCCI 3100, unit 12, TAC USA-1, Escapees 129379
https://instagram.com/silvereagle3100/
SilverEagle6 is offline   Reply With Quote
Old 09-08-2014, 08:54 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
My first thought is damaged tire. I would also check the wheel bearing tightness. I would try a different tire first and watch it closely for wear.
Bill M. is online now   Reply With Quote
Old 09-08-2014, 09:46 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Check bearings NOW! With tire off the ground see if you can feel any "rocking" in the wheel. Compare to one that isnt wearing like that one. You can do that where you get tire replaced.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-09-2014, 04:35 PM   #4
2008 30' Classic
Thanks guys. Went to a local tire shop and checked the bearings...seem to be ok. Decided to put one of my spares on and have driven 200+ miles today and all ok. Hopefully it was a broken belt but will continue to watch and have inspected when we get to Jackson Center.
Old 09-09-2014, 05:30 PM   #5
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Mine did that - the end of the axle was bent upwards - tire was at a slight upwards angle - it must be 90 degrees - if it were a car you would get an alignment - with a AS you get new axle. Look down the AS and see if both rims are straight to each other. I checked with a level and one (the one that wore) was not at 90 degrees.
Silver Hawk is offline   Reply With Quote
Old 09-09-2014, 05:35 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If tire #2 wears....new axle time
Channing
WBCCI# 30676
Old 09-09-2014, 05:42 PM   #7
2008 30' Classic
Roger that!!!
Old 09-11-2014, 04:34 PM   #8
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
We had similar tire wear. Jackson Center did an alignment for us before our trip to Colorado. No visible off-side wearing about 6,000 miles later. AND, the AS seems to pull easier, too. YMMV, of course.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Tire wearing funny. purman Tires 8 06-05-2012 08:36 AM
Right Side Tires Wearing on the Outside Edge halimer Tires 8 06-24-2010 04:07 PM
Plastic Light Covers wearing out in '72 TW RichHog Lights - Interior & Exterior 0 07-09-2009 04:53 PM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
Wearing blue beret optional? yukionna WBCCI Forum 31 05-16-2006 05:27 PM
