11-03-2010, 08:29 AM
Islander
2005 28' International CCD
Deer Harbor
, ORCAS ISLAND WA
replacing tires
what is the correct way to lift trailer to raise both tires off the ground so as to replace both tires???
thanks
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
11-03-2010, 08:32 AM
Oswego
Most agree that it is best to lift by the axle mounting plate between the wheels.
Search on "jacking" and I'm sure you will find a lot of posts on the subject.
11-03-2010, 09:40 AM
1968 24' Tradewind
Oxford,
, Mississippi
I like to use a short piece of 4x4 between the jack pad (3 ton floor jack) and the frame. Distributes the load over a larger area.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
11-03-2010, 09:45 AM
Common Sense
There is supposed to be a spot under the frame behind the wheels and axles marked as the place to lift. However, many trailers more than a few years old are missing the markings.
That being said, I usually jack on the bottom of the axle plate between the wheels as "dznf0g" has suggested.
Regards,
Steve
11-03-2010, 10:06 AM
Oswego
I agree with this if you are using a floor jack with a rather large lifting pad. I wouldn't do it with a bottle jack with a tiny pad. Makes for a really shaky setup.
11-03-2010, 11:24 AM
1977 27' Overlander
Carrollton
I just did this by placing the truck scissor jack behind (toward bumper) the back tandem and in doing this keeps the jack out of the way of wheel changes.
11-03-2010, 12:19 PM
Oswego
Careful with the truck scissors jack. They are designed to lift a CORNER of the specific vehicle in which they are installed. So their rating may only be 2000 lbs. or so. Know the weight of your trailer! If I lift one side of my trailer it's about 4000 lbs. NOT a good idea with the truck jack. I have seen many a scissor jacks misused and collapse. They are not a duty jack, but rather a very occasional use emergency jack.
11-03-2010, 12:25 PM
Common Sense
Not a scissors jack, but I have lifted one side of my '01 25' several times with the truck screw jack from my GMC 3/4 ton with no problems. It didn't even seem to be in a bind at all....don't know, but could be the 3/4 toners have stronger jacks than the 1/2 tons?
Regards,
Steve
11-03-2010, 12:34 PM
Oswego
Probably...just know your trailer weights. Look for a label on the jack....or in the owner's manual. I'm not sure they list a capacity or not. I still believe most, if not all, jacks included in a vehicle are not designed of the duty cycle of constant use. They are meant for emergency use.
11-04-2010, 05:49 AM
1977 27' Overlander
Carrollton
I forgot to mention that after I lifted the trailer, and I've done this many
times, I put under two (2) 3000lb harbor freight jack stands and lowered
the trailer onto those while I did the wheel work. No I would not trust
a half-ton truck scissor jack for any length of time. Thanks for clarifying
that.
Ken
