Old 12-19-2015, 03:24 PM   #1
comprose's Avatar
1999 31' Land Yacht
Kingston , Washington
Replacing tire valve stems
Heading soon to Les Schwab's to install metal stems to replace rubber ones (plus a couple of new extenders) currently on my tires. Also a good opportunity to have tires inspected. Question: should I have the wheels balanced to allow for the small added weight? And what about the added weight of TPMS senders when I add them?
Mike
comprose is offline   Reply With Quote
Old 12-19-2015, 03:28 PM   #2
2006 30' Safari
Divide , Colorado
Would probably be a real good idea. The weights used to achieve balance are usually fairly small. So adding TPMS/metal stems would be like adding an additional small weight to the rim. Would be worth the piece of mind.
gwydir is offline   Reply With Quote
Old 12-19-2015, 03:29 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Since they are breaking the tire down, I would rebalance.
CRH is online now   Reply With Quote
Old 12-19-2015, 06:27 PM   #4
2005 19' Safari
GLENDALE , AZ
If you have Centramatics, I wouldn't bother. Otherwise, it depends on how much tread has worn off since the tires were last balanced, and the difference in weight between the old stems and the new ones.
If there is very little treadwear, the wear is evenly distributed, and the valve stems weigh about the same, rebalancing shouldn't be necessary, assuming the tire tech makes sure that no weights fall off or are moved, and the tire remains in the same orientation on the wheel, which should be standard practice.
Old 12-19-2015, 09:11 PM   #5
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
Have them rebalanced. Weights could have been lost since the last time. Les Schwab will rebalance for free.
Sam
samb is offline   Reply With Quote
Old 12-20-2015, 10:59 AM   #6
gecko's Avatar
2009 28' International
Pacific Palisades , California
Sam
Sam has it just right. Doesn't hurt, may help, tires are off anyway, and it's free.
gecko is offline   Reply With Quote
Old 12-20-2015, 12:24 PM   #7
2016 30' Classic
Erie , Colorado
Have them do the balancing with your TPMS sensors installed.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
Dill TPMS Tire pressure monitor valve stems TexasToaster Tires 15 11-19-2015 11:11 AM
Tire Valve Stems Airperson Tires 11 04-30-2011 05:22 AM
New Tire Problem Chinese valve stems HowieE Tires 23 09-05-2008 10:20 AM
Valve Stems LKappenman Wheels, Hubs & Bearings 5 08-08-2002 08:34 AM
